Hi there, I was following the tutorial https://www.balena.io/blog/build-an-environment-and-air-quality-monitor-with-raspberry-pi/
Tried it with two different Pi Zero W’s and also different SD cards, flashing on Windows and Mac OS, always resulting in the following issue after executing
balena push
The error is
[sensor] Step 8/11 : WORKDIR /usr/src/app
[sensor] Using cache
[sensor] —> 8f332c9e6c91
[sensor] Step 9/11 : COPY ./scripts ./scripts
[sensor] —> 49a7feee0c0c
[sensor] Step 10/11 : RUN chmod +x scripts/*.py
[sensor] —> e9e76446e216
[sensor] Step 11/11 : CMD /usr/src/app/scripts/take_measurement.py
[sensor] —> c21b5aee0122
[sensor] Successfully built c21b5aee0122
[grafana] —> Running in 52ac67971536
[grafana] /bin/sh: 1: /usr/src/app/download.sh: Permission denied
[grafana]
[grafana] Removing intermediate container 52ac67971536
[Info] Uploading images
[grafana] The command ‘/bin/sh -c /usr/src/app/download.sh “raspberry-pi”’ returned a non-zero code: 126
[Error] Service: grafana
[Error] Error: The command ‘/bin/sh -c /usr/src/app/download.sh “raspberry-pi”’ returned a non-zero code: 126
Remote build failed
Additional information may be available in debug mode. Prefix the command
line with DEBUG=1, i.e.: DEBUG=1 balena ...
https://forums.balena.io
Any help appreciated I am really running out of ideas…
