Hi! I’m building a multi-room setup using a Raspberry Pi 4 as the server and multiple raspberry Pi Zero Ws as clients. All of the Pis will be using external USB DACs. The living room (where the Pi 4 Server will be) also has a turntable, so I was wondering if there was any way to incorporate it as a source into the setup? The turntable has a built in preamp, so could I theoretically get something like the Behringer UCA222, connect the turntable to its RCA inputs, use that as the USB DAC for the Pi 4 server, and then broadcast the turntable to the other Pis in the system?
