Add nginx reverse proxy
hi so i have cups and pi hole installed, now i want them both to be accessible using nginx, if not nginx then traefik maybe because its listed on your article two projects one device, but i cannot find it at all, help me with it please
@ajlennon could you please help @Gamer-20A to deploy traefik on this multi-app scenario?
Of course @mpous !
I’ve been having a lot of fun with Traefik this week trying to get it working with MING. I am still basically a noob but have figured out quite a few things. Here is a Dockerfile setting up routing to containers including Node-Red, Grafana and Openthread Border Routers. Basically this is URL path prefix to various ports in containers.
version: '2'
volumes:
  node-red-data:
  grafana-data:
  influxdb-data:
  influxdb-etc:
services:
  # BalenaLabs WiFi-Connect
  wifi-connect:
    image: bh.cr/balenalabs/wifi-connect-rpi
    container_name: wifi-connect
    network_mode: host
    labels:
        io.balena.features.dbus: '1'
        io.balena.features.firmware: '1'
    cap_add:
        - NET_ADMIN
    environment:
        DBUS_SYSTEM_BUS_ADDRESS: "unix:path=/host/run/dbus/system_bus_socket"
    restart: always
  # Node-RED
  node-red:
    build: ./node-red
    container_name: node-red
    volumes:
        - 'node-red-data:/data'
    labels:
      # Enable traefik support for this container
      - "traefik.enable=true"
      # Set service port
      - "traefik.http.services.node-red.loadbalancer.server.port=80"
      # Make it available on the "web" entrypoint which is defined below as :80
      - "traefik.http.routers.node-red.entrypoints=web"
      # Add a specific path prefix that will be expected on the URL suffix
      - "traefik.http.routers.node-red.rule=PathPrefix(`/node-red`)"
      - "traefik.http.middlewares.strip-node-red-prefix.stripprefix.forceSlash=false"
      - "traefik.http.routers.node-red.middlewares=strip-node-red-prefix"
      # Make sure this rule is processed before OTBR as OTBR includes /node in path
      - "traefik.http.routers.node-red.priority=5"
      - "io.balena.features.dbus=true"
      - "io.balena.features.sysfs=true"
      - "io.balena.features.supervisor-api=true"
      - "io.balena.features.balena-api=true"
    environment:
        PORT: 80
        USERNAME: "balena"
        PASSWORD: "balena"
        ENCRIPTION_KEY: "balena"
    cap_add:
        - SYS_RAWIO
    devices:
        - "/dev/mem:/dev/mem"
        - "/dev/gpiomem:/dev/gpiomem"
    depends_on:
      influxdb:
        condition: service_started
      reverse-proxy:
    restart: always
  # Mosquitto MQTT Broker
  mosquitto-broker:
    image: eclipse-mosquitto:1.6.15
    container_name: mqtt
    ports:
      - "1883:1883"
    restart: always
  # Influxdb
  influxdb:
    image: influxdb:1.7.11
    container_name: influxdb
    volumes:
        - influxdb-data:/var/lib/influxdb
        - influxdb-etc:/etc/influxdb
    restart: always
  # Grafana
  grafana:
    image: bh.cr/balenalabs/dashboard
    container_name: grafana
    volumes:
        - "grafana-data:/data"
    environment:
        - "GF_SERVER_ROOT_URL=/grafana"
        - "GF_SERVER_SERVE_FROM_SUB_PATH=true"
    labels:
      # Set service port
      - "traefik.http.services.grafana.loadbalancer.server.port=80"
      - "traefik.http.routers.grafana.entrypoints=web"
      - "traefik.http.routers.grafana.rule=PathPrefix(`/grafana`)"
    depends_on:
      influxdb:
      reverse-proxy:
    restart: always
  # OpenThread Border Router + MQTT-SN Gateway
  openthread-border-router:
    build: ./openthread-otbr
    devices:
      - /dev/ttyACM0:/dev/ttyACM0
    environment:
# For build
      - RADIO_URL="spinel+hdlc+uart:///dev/ttyACM0"
      - BACKBONE_INTERFACE="eth0"
# For run
      - RUN_MQTT_SNGATEWAY=1
      - SENSORNET="udp6"
      - BROKER_NAME="mqtt.dynamicdevices.co.uk"
      - BROKER_PORT=1883
      - BROKER_SECURE_PORT=8883
      - GATEWAY_PORT=10000
      - GATEWAY_IPV6_PORT=10000
      - MULTICAST_IPV6="ff03::1"
      - MULTICAST_IPV6_PORT=10000
      - MULTICAST_IPV6_IF="wpan0"
      - MULTICAST_IPV6_HOPS=3
      - AUTO_FORM_NETWORK=1
      - THREAD_CHANNEL=15
      - THREAD_PAN_ID=0x4444
      - THREAD_EXT_PAN_ID="3333333344444444"
      - THREAD_NETWORK_NAME="INST"
      - THREAD_NETWORK_KEY="33334444333344443333444433334444"
      - THREAD_IPV6_PREFIX="fd11:22::/64 pasor"
    labels:
      - "io.balena.features.kernel-modules=1"
      # Set service port
      - "traefik.http.services.openthread-border-router.loadbalancer.server.port=80"
      - "traefik.http.services.openthread-border-router-rest.loadbalancer.server.port=8081"
      - "traefik.http.routers.openthread-border-router.entrypoints=web"
      - "traefik.http.routers.openthread-border-router-main.entrypoints=web"
      - "traefik.http.routers.openthread-border-router-rest.entrypoints=web"
      # Set service for routers
      - "traefik.http.routers.openthread-border-router.service=openthread-border-router"
      - "traefik.http.routers.openthread-border-router-main.service=openthread-border-router"
      - "traefik.http.routers.openthread-border-router-rest.service=openthread-border-router-rest"
      # NOTE: Really need to rework the OTBR and REST servers here as we're working around their paths
      - "traefik.http.routers.openthread-border-router.rule=( PathPrefix(`/otbr`) || PathPrefix(`/res`) )"
      - "traefik.http.routers.openthread-border-router-main.rule=( Path(`/`) )"
      - "traefik.http.routers.openthread-border-router-rest.rule=( PathPrefix(`/diagnostics`) || PathPrefix(`/node`) || PathPrefix(`/networks`))"
      - "traefik.http.middlewares.strip-otbr-prefix.stripprefix.prefixes=/otbr"
      - "traefik.http.middlewares.strip-otbr-prefix.stripprefix.forceSlash=false"
      - "traefik.http.routers.openthread-border-router.middlewares=strip-otbr-prefix"
      - "traefik.http.middlewares.redirect-root.redirectregex.regex=^/"
      - "traefik.http.middlewares.redirect-root.redirectregex.replacement=/otbr"
      - "traefik.http.routers.openthread-border-router-main.middlewares=redirect-root"
      # Make sure priority is lower than node-red
      - "traefik.http.routers.openthread-border-router.priority=4"
      - "traefik.http.routers.openthread-border-router-rest.priority=4"
    sysctls:
      net.ipv6.conf.all.disable_ipv6: 0
      net.ipv4.conf.all.forwarding: 1
      net.ipv6.conf.all.forwarding: 1
    depends_on:
      reverse-proxy:
    privileged: true
    restart: always
  # Traefik Reverse Proxy
  reverse-proxy:
    build: ./reverse-proxy
    command:
      - "--log.level=DEBUG"
      - "--accesslog=true"
      - "--accesslog.filepath=/var/log/traefik.log"
      - "--api.dashboard=true"
      # Uncomment this to enable the Traefik WebUI on port :8080
      - "--api.insecure"
      - "--providers.docker=true"
      - "--providers.docker.endpoint=unix:///var/run/balena-engine.sock"
      #- "--providers.docker.exposedbydefault=true"
      - "--entrypoints.web.address=:80"
    ports:
      # The HTTP port
      - "80:80"
      # The Dashboard port
      - "8080:8080"
    labels:
      # So that Traefik can listen to the Docker events
      - "io.balena.features.balena-socket=1"
    restart: always
Let me know what you are trying to do and maybe I can help :slight_smile:
A couple of things that helped me, and I have them set here, were to
  • enable the WebUI on :8080. This lets you see the routers and middlewares and services, how they are wired up, and if any failed to be configured
  • logging to a local log file. You can tail this file and see what requests are being forwarded to what internal services and so forth
