I’m glad to see you’re still fighting! We’re working in the background to try and work out your Beaglebone Green issue with CANbus, but moving over to a more capable device might be a good step anyway.
So to this issue, you can use our special configurable variables to set DT Overlays:
This page gives some guidance for the overlay you’re trying to use:
Hope this helps. Keep going, we’ll get you sorted!
Hello! I also need overlay support for MCP2517FD for raspberry pi 3B+.
Can you provide instructions on how to add the custom overlay?
Thank you in advance
Thank you very much Alexandru! A little more help here.
So the PR has three file changes:
layers/meta-balena-raspberrypi/conf/layer.conf
Seems ok I’m just not sure if I should name my dtbo file 2xmcp2517fd or mcp2517fd. Should this be defined by how it is named in the raspberry kernel system?
layers/meta-balena-raspberrypi/recipes-kernel/linux/linux-raspberrypi_%.bbappend
Is straight forward
layers/meta-balena-raspberrypi/recipes-kernel/linux/linux-raspberrypi/0009-seeed studio-can-bus-v2-Add-dtbo-for-this-can-bus.patch
About my patch file, should it have prefix 0001, 0009 or something else?
Concerning the content of the patch file, the diff is extracted from where? A quick search lead me here but I can’t find arch/arm/boot/dts/overlays/Makefile path
I use raspberry pi 3 model B maybe not the correct branch?
Also I have located 2xMCP2517FD.dtbo and 2xMCP2517FD-overlay.dts files here, should I add these files somehow of are they already located in raspberry os (not balena os).
Sorry for the noob questions first time trying to figure these out! Hopefully I will soon be able to contribute more independently!
I clone and recompile the raspberrypi 5.4.y kernel for arm64 arch, just following this guide : Kernel building - Raspberry Pi Documentation.
Then I just copy the mcp25xfd.dtbo to resin-boot/boot/overlays partition, and add the correct dtoverlay parameters on balenaCloud device configuration : "spi1-1cs","mcp251xfd,spi0-0,interrupt=25","mcp251xfd,spi1-0,interrupt=24"
Then my Seed HAT (a dual mcp2518fd without rtc) is correctly recognize.
So what’s next step ?
How to get this dts overlay included in next balenaOS release ?
I’m sure mcp2517 and mcp2518 including CAN FD will be used by many people.
MCP2518FP support has been added for the Pi3 (32-bit) and balenaFin devices types in balenaOS 2.77.0+rev1, now available in production. The same will be true of the Pi4 device type in 2-4 weeks. If you need to experiment with a Pi4 now, note that the Pi4 now has the necessary kernel module mcp251xfd.ko, so in theory you can manually copy the mcp251xfd-overlay dtb and set RESIN_HOST_CONFIG_dtoverlay, but we have not tested this. Thank you for asking about MCP2518FP support - future CAN bus users will thank you.
FYI, MCP2518FP support is now live for PI4. More specifically, balenaOS 2.80.3+rev1 for the “Raspberry Pi 4 (using 64bit OS)” device type now includes the mcp251xfd.dtbo overlay as well as the mcp251xfd.ko kernel module.
@rosswesleyporter Thank you very much. Given the fact that the MCP2515 is NRND, do you think the MCP2518 support will make it into other RPI Balena OS builds, such as RPI Zero W?
