64 bit container on Raspberry pi 3 b+?
Is it possible to use a 64 bit base image on Raspberry Pi 3 b+ using balenaCloud / balenaOS?
It looks like it’s not currently supported, but I may be misunderstanding the issue I found here: https://github.com/balena-os/balena-raspberrypi/issues/181
Will
I just wanted to bump this back up / see if 64 bit support is on the roadmap :slight_smile:
Hi @wlisac, it seems to me that the ability to build a 64 bit version of balena OS for RPi has just been added - although the raspberrypi3-64.coffee is still marked as experimental and is not available for download as a pre-built image from the website, so not sure how much testing went into it or whether it’s just a matter of time until Balena guys update the docs / distribute the image.
Hey guys,
I want to run some containers that are built for 64 OS. To do this, I need to run a balenaOS in 64 version, am I right? It has nothing to do with base images since they are pre-built. ?
There is now a beta version of balenaOS for the Raspberry Pi 3. To use this feature, create a new balenaCloud application, and use the Raspberry Pi 3 (using 64bit OS) device type.
Cheers,
Trevor Sullivan
Hey,
BalenaOs is available in 64bit only for Raspberry pi or there are other supported architectures as well (like generix x86).
Hey @odyslam,
BalenaOS is supported for generic x86-64 arch also: https://github.com/balena-os/balena-intel.
From the dashboard select the Intel NUC application and it should work.
Regards!
