I tried to change the xserver service in my Balena project from balenablocks to balenalabs.
Is it correct that balenalabs is newer than balenablocks ? Or which one do you recommend ?
The following error occurs when trying to go from balenablocks to balenalabs version of xserver:
Before, I had the following inside the docker-compose.yml File:
xserver:
image: balenablocks/xserver
restart: always
privileged: true
labels:
io.balena.features.dbus: "1"
volumes:
# when we start, a UNIX socket is mounted in this directory, for communication to the X server
- xserver-volume:/tmp/.X11-unix
For the above, everything works and I can push to the Balena fleet without problems.
However, if I exchange the balenablocks/xserver with bh.cr/balenalabs/xserver-amd64, such as:
xserver:
image: bh.cr/balenalabs/xserver-amd64
restart: always
privileged: true
labels:
volumes:
Then I get the following error message when trying to push to the balena fleet :
[Error] Service: xserver
[Error] Error: (HTTP code 404) unexpected - pull access denied for bh.cr/balenalabs/xserver-amd64, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
[Info] Built on x64_01
Remote build failed
I also tried image: bh.cr/balenalabs/xserver (i.e. without the -amd64). But did not help, same error !!!
Then I tried to upload my own custom Balena Block from a cloned xserver instance. It did it. It worked and under Balena Blocks I find my own custom Block:
Inside the docker-compose.yml File, I exchanged to now take my custom Block, such as:
image: bh.cr/<slug_name>/xserver
or also:
image: bh.cr/<slug_name>/xserver-adm64
It did not work !!!
Again, when trying to push my project to the fleet, I end up once more with the exact same error message:
Remote build failed
What do I need to do ?
Which of the two xserver possibilities do you recommend ? (i.e. balenablocks/xserver or balenalabs/xserver ??)
