We are deploying, using balena deploy, images that have been pre-pushed to docker hub. We deploy using docker-compose.yml files.
The issue we are seeing is that balena deploy doesn’t pull/push the right images to your registry. The symptom is exec format error.
The above screenshot is the result of the following docker-compose file:
version: "2"
services:
# Database instance
actyx:
image: actyx/actyx@sha256:ba041c16786748cd30d334b5063c530a4052bc917ec4362cb49424479ff03324
network_mode: "host"
ports:
- 4001:4001 # Swarm
- 4458:4458 # Admin
- 4454:4454 # API
volumes:
- actyx-data:/data
kiosk:
image: balenablocks/browser
environment:
- REMOTE_DEBUG_PORT=9222
- KIOSK=1
- SHOW_CURSOR=0
ports:
- 35173:35173
- 9222:9222
privileged: true
depends_on:
- app
volumes:
actyx-data:
driver: local
As you can see, the wrong architecture for balenablocks/browser was chosen.
I know that we can use the @digest format to select the right image, but that is extremely inconvenient since it means changing all relevant docker-compose.ymls whenever we push a new image.
How can I resolve this issue?
