We’re trying to use the WittyPi with Resio.io, however we’re having some problems getting it running with a container. The WittyPi is a power management and RTC board for RPi. When we insert the USB power into the witty pi and press the button the RPi’s red light turns on for one second and then powers off. The WittyPi uses I2C to communicate with the RPi. We run the witty pi installation script (see below) from the Dockerfile, however I suspect the scripts needs to be installed in the base image.
Any suggestions?
Witty Pi installation script:
#!/usr/bin/env bash
[ -z $BASH ] && { exec bash "$0" "$@" || exit; }
#!/bin/bash
# file: installWittyPi.sh
# This script will install required software for Witty Pi.
# It is recommended to run it in your home directory.
# check if sudo is used
if [ "$(id -u)" != 0 ]; then
echo 'Sorry, you need to run this script with sudo'
exit 1
fi
# target directory
DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )/wittyPi"
# error counter
ERR=0
echo '================================================================================'
echo '| |'
echo '| Witty Pi Software Installing Script |'
echo '| |'
# enable I2C on Raspberry Pi
echo '>>> Enable I2C'
if grep -q 'i2c-bcm2708' /etc/modules; then
echo 'Seems i2c-bcm2708 module already exists, skip this step.'
else
echo 'i2c-bcm2708' >> /etc/modules
fi
if grep -q 'i2c-dev' /etc/modules; then
echo 'Seems i2c-dev module already exists, skip this step.'
else
echo 'i2c-dev' >> /etc/modules
fi
if grep -q 'dtparam=i2c1=on' /boot/config.txt; then
echo 'Seems i2c1 parameter already set, skip this step.'
else
echo 'dtparam=i2c1=on' >> /boot/config.txt
fi
if grep -q 'dtparam=i2c_arm=on' /boot/config.txt; then
echo 'Seems i2c_arm parameter already set, skip this step.'
else
echo 'dtparam=i2c_arm=on' >> /boot/config.txt
fi
if grep -q 'dtoverlay=pi3-miniuart-bt' /boot/config.txt; then
echo 'Seems setting Pi3 Bluetooth to use mini-UART is done already, skip this step.'
else
echo 'dtoverlay=pi3-miniuart-bt' >> /boot/config.txt
fi
if grep -q 'core_freq=250' /boot/config.txt; then
echo 'Seems the frequency of GPU processor core is set to 250MHz already, skip this step.'
else
echo 'core_freq=250' >> /boot/config.txt
fi
if [ -f /etc/modprobe.d/raspi-blacklist.conf ]; then
sed -i 's/^blacklist spi-bcm2708/#blacklist spi-bcm2708/' /etc/modprobe.d/raspi-blacklist.conf
sed -i 's/^blacklist i2c-bcm2708/#blacklist i2c-bcm2708/' /etc/modprobe.d/raspi-blacklist.conf
else
echo 'File raspi-blacklist.conf does not exist, skip this step.'
fi
# install i2c-tools
echo '>>> Install i2c-tools'
if hash i2cget 2>/dev/null; then
echo 'Seems i2c-tools is installed already, skip this step.'
else
apt-get install -y i2c-tools || ((ERR++))
fi
# install wiringPi
if [ $ERR -eq 0 ]; then
echo '>>> Install wiringPi'
if hash gpio 2>/dev/null; then
echo 'Seems wiringPi is installed already, skip this step.'
else
if hash git 2>/dev/null; then
echo "Git is ready to go..."
else
echo "Git is missing, install it now..."
apt-get install -y git || ((ERR++))
fi
git clone git://git.drogon.net/wiringPi || ((ERR++))
cd wiringPi
./build
cd ..
fi
fi
fi
# install wittyPi
echo '>>> Install wittyPi'
if [ -f wittyPi ]; then
echo 'Seems wittyPi is installed already, skip this step.'
else
wget http://www.uugear.com/repo/WittyPi/LATEST -O wittyPi.zip || ((ERR++))
unzip wittyPi.zip -d wittyPi || ((ERR++))
cd wittyPi
chmod +x wittyPi.sh
chmod +x daemon.sh
chmod +x syncTime.sh
chmod +x runScript.sh
sed -e "s#/home/pi/wittyPi#$DIR#g" init.sh >/etc/init.d/wittypi
chmod +x /etc/init.d/wittypi
update-rc.d wittypi defaults
cd ..
sleep 2
rm wittyPi.zip
fi
fi
echo
echo '>>> All done. Please reboot your Pi :-)'
else
echo '>>> Something went wrong. Please check the messages above :-('
fi
# base-image for python on any machine using a template variable,
# see more about dockerfile templates here:http://docs.resin.io/pages/deployment/docker-templates
FROM resin/%%RESIN_MACHINE_NAME%%-python
# use apt-get if you need to install dependencies,
# for instance if you need ALSA sound utils, just uncomment the lines below.
RUN apt-get update && apt-get --assume-yes install python3-gpiozero python-gpiozero sshfs python-dev libzmq3-dev rsync sshpass unzip
# Install bridging depeendencies
RUN apt-get install -yq --no-install-recommends \
parprouted dhcp-helper avahi-daemon avahi-daemon avahi-utils libnss-mdns
# For Avahi, DNS and DBUS
RUN apt-get --assume-yes install avahi-daemon avahi-utils libnss-mdns dbus
# For Paramiko
RUN apt-get --assume-yes install libssl-dev libffi6 libffi-dev
# OpenSSH
RUN apt-get update && apt-get install -yq --no-install-recommends \
openssh-server && \
# here we set up the config for openSSH.
RUN mkdir /var/run/sshd \
&& echo 'root:resin' | chpasswd \
&& sed -i 's/PermitRootLogin without-password/PermitRootLogin yes/' /etc/ssh/sshd_config \
&& sed -i 's/UsePAM yes/UsePAM no/' /etc/ssh/sshd_config
# Set our working directory
WORKDIR /usr/src/app
COPY ./resources/dhcp-helper /etc/default/dhcp-helper
COPY ./resources/avahi-daemon.conf /etc/avahi/avahi-daemon.conf
# Copy requirements.txt first for better cache on later pushes
COPY ./requirements.txt /requirements.txt
# pip install python deps from requirements.txt on the resin.io build server
RUN pip install -r /requirements.txt
# Install Witty Pi
COPY ./resources/install_witty.sh /install_witty.sh
RUN chmod +x /install_witty.sh
RUN (cd / && ./install_witty.sh)
# This will copy all files in our root to the working directory in the container
COPY . ./
WORKDIR /usr/src/app/src
# switch on systemd init system in container
ENV INITSYSTEM on
# Start the main app
CMD ["./start.sh"]
Witty Pi Install Script:
#!/usr/bin/env bash
#!/bin/bash
exit 1
fi
# target directory
# error counter
ERR=0
echo '| |'
echo '| |'
else
fi
else
fi
else
fi
else
fi
else
fi
else
fi
else
fi
# install i2c-tools
else
fi
# install wiringPi
else
else
fi
cd wiringPi
./build
cd ..
fi
fi
fi
# install wittyPi
else
cd wittyPi
chmod +x wittyPi.sh
chmod +x daemon.sh
cd ..
sleep 2
rm wittyPi.zip
fi
fi
echo
else
fi
We’ve had a look at the Dockerfile now, and notice that you’re actually running the script from within it. Because we build containers on separate build machines and not the device they’ll eventually run on, this will not work as none of the devices or boot data is available.
To successfully get this running, you’ll need to take the Witty Pi Install script and break it up into several parts:
For all of the sections which use the /boot/config.txt file, you’ll either need to set config environment variables or manually alter the config.txt file on the SD card you’re using on the Pi, to set the relevant variables. Examples of how to do this can be found on this page.
For sections that operate on Linux specific parts, such as the enabling of subsystem, you’ll need to run this as part of your startup script (start.sh looking at your Dockerfile). Something to be aware of is that the I2C system needs to be specifically initialised at startup, see the I2C section of the link above to see how to do this.
Another thing that came to mind, that module blacklists do not work within containers, as the hostOS mounts the modules, instead the start script have to rmmod the unwanted modules, if I recall correctly?
How do I set these up as environment variables? I’m not sure which part of the string is the key and value. Also, does the ‘=’ sign get automatically added?
For example:
[Key] RESIN_HOST_CONFIG_dtparam=i2c1=
[Value] on
or
[Value] on
or
[Value] i2c1=on
Basically RESIN_HOST_CONFIG_variable set to value: RESIN_HOST_CONFIG_dtoverlay set to pi3-miniuart-bt.
I think you only need to set the dtoverlay and core_freq values, as the other two about i2c should be already enabled by default (will double-check it in a bit, though).
(If needed, it would be set as RESIN_HOST_CONFIG_dtparam to i2c1=on, because dtparam is the variable name. See for example the Raspberry Pi documentation on config.txt )
Sorry to revive a really old thread. I have just installed wittypi dependencies into a balena debian+python image. I think I have got all of the required programmes working. However I have hit a stumbling block, when the wittyPi issues a shutdown command (which usually turns of a pi) the container restarts but as it is run as part of a multi-container setup the board does not turn off. Is there a way I can give the container privileges or send information to the supervisor to issue a safe shutdown?
I have found a solution by using the advice on here - interacting with supervisor. This allows my ‘wittypi container’ to send a command to the supervisor to shutdown the containers and board.
The wittypi shuts power completely to the pi after 5-8 seconds of issuing the command. Is there a way I can check that all of the containers have fully shut down within 8 seconds? I’m a bit concerned that the wittypi might be cutting off the power before a full safe shutdown has been acheived.
