Same as title
Or any other way change the settings for sensor?
Hi @bbq2722 which sensor do you mean exactly can you provide a link?
@bbq2722 it’s a different hat from a different supplier and it uses quite different ICs from the original senseHat so the senseHat library won’t work for that, in order to make it work with balenaSense you have to build support for it.
@bbq2722 I have created a feature request for you here https://github.com/balena-io-projects/balena-sense/issues/51 since balenaSense is an open source project we are always open for new PRs.
Thank you so much, can’t wait the update!
