For some reason when I plug my resin into my companies network via ethernet, it doesn’t want to accept it and doesn’t even show up on any local networks on netstat for me to ping. However, if I run it on wifi, it shows up fine.
Does anyone know why this would be the case and what I can do to fix it?
Here are my logs from journalctl -fn 100 -u NetworkManager
Connecting to abc123...
Spawning shell...
Welcome to ResinOS
root@f995498:~# journalctl -fn 100 -u NetworkManager
-- Logs begin at Mon 2018-10-15 14:19:10 UTC. --
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3053] dns-mgr[0x55a02509d120]: init: dns=default, rc-manager=resolvconf
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3057] rfkill1: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.5/0000:3a:00.0/ieee80211/phy0/rfkill1)(driver iwlwifi)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3057] manager[0x55a025091040]: rfkill: WiFi hardware radio set enabled
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3057] manager[0x55a025091040]: rfkill: WWAN hardware radio set enabled
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3267] settings: Loaded settings plugin: NMSKeyfilePlugin (internal)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3276] keyfile: new connection /etc/NetworkManager/system-connections/resin-wifi-01 (a58e405d-fdc2-3649-9339-5bbaea740c76,"resin-wifi-01")
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3285] manager: rfkill: WiFi enabled by radio killswitch; enabled by state file
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3286] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3286] manager: Networking is enabled by state file
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3287] dhcp-init: Using DHCP client 'internal'
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3319] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.12.0/libnm-device-plugin-wwan.so)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3330] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.12.0/libnm-device-plugin-wifi.so)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3360] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.12.0/libnm-device-plugin-bluetooth.so)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3365] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.12.0/libnm-device-plugin-adsl.so)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3372] device (lo): carrier: link connected
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3374] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3380] manager: (eno1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3388] keyfile: add connection in-memory (092abd07-02f5-30d1-a6ea-c0bb4c54ac3d,"Wired connection 1")
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3393] settings: (eno1): created default wired connection 'Wired connection 1'
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.3400] device (eno1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5539] manager: (resin-dns): new Bridge device (/org/freedesktop/NetworkManager/Devices/3)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5605] keyfile: add connection in-memory (1c47377d-aca1-4d7d-8ba0-e22896c32e88,"resin-dns")
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5620] device (resin-dns): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5648] device (resin-dns): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5675] device (resin-dns): Activation: starting connection 'resin-dns' (1c47377d-aca1-4d7d-8ba0-e22896c32e88)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5686] manager: (sit0): new IPTunnel device (/org/freedesktop/NetworkManager/Devices/4)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5706] wifi-nl80211: (wlp58s0): using nl80211 for WiFi device control
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5708] device (wlp58s0): driver supports Access Point (AP) mode
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5718] manager: (wlp58s0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/5)
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.5743] device (wlp58s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7790] device (resin-dns): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7822] device (resin-dns): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7834] device (resin-dns): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7844] device (resin-dns): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7859] device (resin-dns): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7876] device (resin-dns): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7893] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7940] device (resin-dns): Activation: successful, device activated.
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7956] bluez: use BlueZ version 5
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.7960] modem-manager: ModemManager available
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.8053] bluez5: NAP: added interface 94:B8:6D:FD:EA:ED
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.8093] supplicant: wpa_supplicant running
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.8095] device (wlp58s0): supplicant interface state: init -> starting
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.8318] sup-iface[0x55a02505c990,wlp58s0]: supports 5 scan SSIDs
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.8330] device (wlp58s0): supplicant interface state: starting -> ready
Oct 15 14:19:12 f995498 NetworkManager[677]: <info> [1539613152.8331] device (wlp58s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.4302] manager: (balena0): new Bridge device (/org/freedesktop/NetworkManager/Devices/6)
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5040] manager: (br-2a8f84ea7954): new Bridge device (/org/freedesktop/NetworkManager/Devices/7)
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5174] manager: (supervisor0): new Bridge device (/org/freedesktop/NetworkManager/Devices/8)
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5311] device (supervisor0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5329] keyfile: add connection in-memory (991ea01c-c636-4fdb-aa0e-9dda4237a828,"supervisor0")
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5332] device (supervisor0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5337] device (supervisor0): Activation: starting connection 'supervisor0' (991ea01c-c636-4fdb-aa0e-9dda4237a828)
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5338] device (supervisor0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5340] device (supervisor0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5341] device (supervisor0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5342] device (supervisor0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5345] device (supervisor0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5346] device (supervisor0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Oct 15 14:19:13 f995498 NetworkManager[677]: <info> [1539613153.5364] device (supervisor0): Activation: successful, device activated.
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0457] policy: auto-activating connection 'resin-wifi-01' (a58e405d-fdc2-3649-9339-5bbaea740c76)
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0465] device (wlp58s0): Activation: starting connection 'resin-wifi-01' (a58e405d-fdc2-3649-9339-5bbaea740c76)
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0467] device (wlp58s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0471] manager: NetworkManager state is now CONNECTING
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0476] device (wlp58s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0479] device (wlp58s0): Activation: (wifi) access point 'resin-wifi-01' has security, but secrets are required.
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0479] device (wlp58s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0506] device (wlp58s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0511] device (wlp58s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0514] device (wlp58s0): Activation: (wifi) connection 'resin-wifi-01' has security, and secrets exist. No new secrets needed.
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0514] Config: added 'ssid' value 'WIFI NAME HERE'
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0515] Config: added 'scan_ssid' value '1'
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0515] Config: added 'bgscan' value 'simple:30:-80:86400'
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0515] Config: added 'key_mgmt' value 'WPA-PSK'
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0515] Config: added 'auth_alg' value 'OPEN'
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0515] Config: added 'psk' value '<hidden>'
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0798] device (wlp58s0): supplicant interface state: ready -> authenticating
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.0901] device (wlp58s0): supplicant interface state: authenticating -> 4-way handshake
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1028] device (wlp58s0): supplicant interface state: 4-way handshake -> completed
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1028] device (wlp58s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'WIFI NAME HERE'.
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1030] device (wlp58s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1035] dhcp4 (wlp58s0): activation: beginning transaction (no timeout)
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1380] dhcp4 (wlp58s0): address 192.168.3.164
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1380] dhcp4 (wlp58s0): plen 24
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1380] dhcp4 (wlp58s0): expires in 43200 seconds
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1381] dhcp4 (wlp58s0): nameserver '192.168.3.1'
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1381] dhcp4 (wlp58s0): hostname 'f995498'
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1381] dhcp4 (wlp58s0): gateway 192.168.3.1
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1385] dhcp4 (wlp58s0): state changed unknown -> bound
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1415] device (wlp58s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1432] device (wlp58s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1439] device (wlp58s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1447] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1527] manager: NetworkManager state is now CONNECTED_SITE
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1531] policy: set 'resin-wifi-01' (wlp58s0) as default for IPv4 routing and DNS
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1537] dns-mgr: Writing DNS information to /sbin/resolvconf
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1725] device (wlp58s0): Activation: successful, device activated.
Oct 15 14:19:16 f995498 NetworkManager[677]: <info> [1539613156.1743] manager: NetworkManager state is now CONNECTED_GLOBAL
Oct 15 14:19:18 f995498 NetworkManager[677]: <info> [1539613158.5509] manager: startup complete
Oct 15 14:19:24 f995498 NetworkManager[677]: <info> [1539613164.5212] manager: (resin-vpn): new Tun device (/org/freedesktop/NetworkManager/Devices/9)
