Background:
I’ve setup my Raspberry Pi 4 B with BalenaOS. For context during the flashing process I chose to define “WiFi + Ethernet” (and provided a the SSID and passphrase for a local WiFi network).
I then created this git repo: GitHub - hilibari/balena-wifi-connect-not-working
I would really appreciate some help troubleshooting my issues with setting up wifi-connect.
My situation:
When I turn on my Raspberry Pi 4B it automatically connects to the preconfigured local network. I then use the Terminal within BalenaCloud to run nmcli connection down id "localNetworkNameGoesHere" on the Host. This successfully disconnects the Raspberry Pi 4B from the local network; it also successfully triggers the wifi-connect to broadcast the “WiFi Connect” SSID and it also successfully allows me to connect to the “access point”. However, I automatically get redirected to a broken page – a page that is empty (see screenshot below).
What can I do to solve this issue? Are there any errors inside my git repo?
Screenshot of broken page:
