I used wifi-connect to create hotspot on JETSON TX2. In logs it shows successfully that access point is created but i am not able to find access point.
It successfully showing - Access point ‘TEGRA’ created , but i am not able to see it at all.
Can you also share your docker-compose / dockerfile ?
Enabling support access to your device and giving us the dashboard url of it might help us further investigate this.
Enabling support access ?
Do i need to buy paid plan ? As of now i am working on 2 devices but in next 3 months will move to maximum of 10 devices only.
Hello @yyogeshwar support access can be enabled from the dashboard, to reach that you must go to the device summary page (you can reach that by clicking on an application and then selecting one of the devices that belong to the application). Once you are on that page there should be a drop-down menu in the top-right corner of the box with all the device information (the icon is an arrow pointing down) From there you should be able to grant support access, which will allow balena support agents to access your device through SSH.
Support is available for any plan, no need to upgrade for that. The personal plan should allow up to 10 devices so that should be good for now but have a look at https://www.balena.io/pricing for more information on the paid plans.
yes , i am able to see other wifi and also able to connect to wifi but when i ran wifi-connect app , in logs shows everything is successful but does not shows any hotspot which wifi-connect app created
Hi, I see the device’s connected to two networks, one wired and one wireless (the hotspot). Could you try without being connected to any network first? So, just using wifi-connect. NetworkManager disables auto-scanning for networks when there’s already an active connection, in this case the wired one
