I’ve got an app that’s meant to broadcast as an Apple Time Capsule for backups via my WiFi but the logs show the app exiting after the script’s run.
Full source is here
Entrypoint file:
#!/bin/bash
# create the mount directory
mkdir -p /media/tm
# add fstab entry
echo "/dev/sda2 /media/tm hfsplus force,rw,user,auto 0 0" >> /etc/fstab
# mount it all
mount -a
systemctl enable avahi-daemon
systemctl enable netatalk
# start services
service dbus start
service avahi-daemon start
netatalk start
Logs
07.07.17 18:24:44 (+0500) Restarting application 'registry2.resin.io/pwnbox/8dc5899d88c88cbd30f9a6196d7a310a3397581f'
07.07.17 18:10:25 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:10:25 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:10:26 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:10:26 (+0500) Created symlink from /etc/systemd/system/multi-user.target.wants/netatalk.service to /lib/systemd/system/netatalk.service.
07.07.17 18:10:26 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:10:26 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon[ ok .
07.07.17 18:10:29 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:10:29 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:10:29 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:10:30 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:10:30 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:10:30 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:10:30 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 57 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:10:30 (+0500) [ ok .
07.07.17 18:10:33 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:10:33 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:10:33 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:10:33 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:10:33 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:10:34 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:10:34 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:10:34 (+0500) [ ok .
07.07.17 18:10:36 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:10:36 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:10:36 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:10:36 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:10:37 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:10:37 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:10:37 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:10:37 (+0500) [ ok .
07.07.17 18:10:40 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:10:40 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:10:40 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:10:40 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:10:40 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:10:40 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:10:40 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:10:40 (+0500) [ ok .
07.07.17 18:10:44 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:10:44 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:10:44 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:10:44 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:10:44 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:10:44 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:10:44 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:10:44 (+0500) [ ok .
07.07.17 18:10:49 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:10:49 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:10:49 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:10:49 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:10:50 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:10:50 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:10:50 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:10:50 (+0500) [ ok .
07.07.17 18:10:59 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:10:59 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:10:59 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:10:59 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:10:59 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:10:59 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:10:59 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:10:59 (+0500) [ ok .
07.07.17 18:11:14 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:11:14 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:11:14 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:11:15 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:11:15 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:11:15 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:11:15 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 79 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:11:15 (+0500) [ ok .
07.07.17 18:11:43 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:11:44 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:11:44 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:11:44 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:11:44 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:11:44 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:11:44 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:11:44 (+0500) [ ok .
07.07.17 18:12:38 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:12:38 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:12:38 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:12:39 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:12:39 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:12:39 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:12:39 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:12:39 (+0500) [ ok .
07.07.17 18:14:24 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:14:24 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:14:24 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:14:24 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:14:25 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:14:25 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:14:25 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:14:25 (+0500) [ ok .
07.07.17 18:17:52 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:17:52 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:17:52 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:17:52 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:17:53 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:17:53 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:17:53 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:17:53 (+0500) [ ok .
07.07.17 18:24:44 (+0500) mount: /dev/sda2 is already mounted or /media/tm busy
07.07.17 18:24:45 (+0500) Synchronizing state for avahi-daemon.service with sysvinit using update-rc.d...
07.07.17 18:24:45 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon defaults
07.07.17 18:24:45 (+0500) Executing /usr/sbin/update-rc.d avahi-daemon enable
07.07.17 18:24:45 (+0500) [....] Removing stale PID file /var/run/dbus/pid.[ ok .
07.07.17 18:24:45 (+0500) [....] Starting system message bus: dbus[ ok .
07.07.17 18:24:45 (+0500) [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 78 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
07.07.17 18:24:45 (+0500) [ ok .
07.07.17 18:24:46 (+0500) Application exited 'registry2.resin.io/pwnbox/8dc5899d88c88cbd30f9a6196d7a310a3397581f'
