OS: Resin OS 2.0.0+rev3 (dev)
Device: Raspberry PI 3
Screen: 7.0 Inch 1024x600 Pixel IPS
Project: resin-io/resin-electronjs
Building and downloading works great, during which the screen is completely black. Once the application has downloaded and run on the pi the screen flickers and displays a white stripe on the left side of the display.
Hey @infining what amount of memory have you allocated to the GPU? by default the RPI family only is setup with 16MB for the GPU. I would recommend setting it somewhat higher, by adding the following to your /boot/config.txt:
gpu_mem=128
start_x=1
@shaunmulligan thanks, will try that out.
edit: why would I need to change start_x to 1? From the resin config.txt:
start_x
Set to “1” to enable the camera module.
Enabling the camera requires gpu_mem option to be specified with a value
of at least 128.
Default 0
#start_x=0
I am not using the camera.
edit2: No go on the gpu_mem=128, same white stripe.
Thank you @shaunmulligan for helping me realize that the config.txt is in the /boot folder of the sd card. Added recommended changes to that file which was listed on the screen’s product page and my problem is resolved:
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
max_usb_current=1
Awesome, glad you got it working @infining
