When are the connections in /mnt/boot/system-connections loaded? I have a cellular connection file that I want loaded when an application in a container starts up. I need to have a cellular connection at the start of my application.
Hello @ronlevine I have som questions.
- What problem do you have setting up your cellular connection?
- What did you try?
- Out of curiosity, why do you need to load a connection file every time your application starts up?
Did you watch this episode with recommendations https://www.youtube.com/watch?v=e5-r_9ggHqI&t=1500s
- What did you try?
Able to set set up the APN with the command: mmcli -m 0 --command AT+CGDCONT=1,“IPV4V6”,“m2m005209.attz”
And have the attached cellular-4g file in the /mnt/boot/system-connection folder, which after boot is copied to /etc/NetworkManager/system-connections/
But, the cellular device (cdc-wdm0) is in the “searching”, not “connected”
In order to make a connection, I had to run the command:
nmcli connect add type gsm ifname cdc-wdm0 con-name cellular-4g apn m2m005209.attz
as shown in https://ubuntu.com/core/docs/networkmanager/configure-cellular-connections
Is there anything else that needs to be done?
- Out of curiosity, why do you need to load a connection file every time your application starts up? No
Hi Ron, I understand that you are able to bring up the cellular connection using mmcli
and nmcli
as you describe above, but when you try to mimic that configuration in a NetworkManager profile, the connection is not working.
Is that right? If so, could you please share the networkmanager profile you are using?
