Thanks for that spanceac, I was having issues with resin-supervisor reverting my RPi’s /config.txt
back to defaults after manually editing /mnt/boot/config.txt
Even after disabling the service, resin-supervisor was self-launching again 15 minutes after boot, causing my changes to config.txt to be lost again. I’ve pasted the logs at the end, it might help others wanting to disable resin_supervisor to find this message.
After some digging I found a systemd timer that seemed the likely culprit, update-resin-supervisor.timer
. I disabled it with
mount -o remount,rw /
systemctl disable update-resin-supervisor.timer
My Raspberry Pi hasn’t rebooted itself in 30 minutes, so it seems to have done the trick.
update-resin-supervisor induced reboot logs:
Jan 15 14:00:08 balena systemd[1]: Starting Resin supervisor...
Jan 15 14:00:09 balena resin-supervisor[1197]: resin_supervisor
Jan 15 14:00:09 balena resin-supervisor[1201]: active
Jan 15 14:00:09 balena systemd[1]: Started Resin supervisor.
Jan 15 14:00:10 balena systemd[1]: Started Resin supervisor updater.
Jan 15 14:00:11 balena sh[1203]: Getting image name and tag...
Jan 15 14:00:11 balena sh[1203]: No supervisor configuration found from API or required variables not set. Using arguments for image and tag.
Jan 15 14:00:11 balena sh[1203]: Set based on arguments image=balena/rpi-supervisor and tag=v9.0.1.
Jan 15 14:00:11 balena sh[1203]: Getting image id...
Jan 15 14:00:14 balena sh[1203]: Supervisor balena/rpi-supervisor:v9.0.1 already downloaded.
Jan 15 14:00:22 balena balenad[686]: time="2019-01-15T14:00:22.041216762Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
Jan 15 14:00:22 balena balenad[686]: time="2019-01-15T14:00:22Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/d6498b06c6b3c7ccb84644094c2804681d500ae468984f29743867b2d34ee588/shim.sock debug=false module=containerd/tasks pid=1257
Jan 15 14:00:26 balena balenad[686]: time="2019-01-15T14:00:26.737042317Z" level=warning msg="unknown container" container=d6498b06c6b3c7ccb84644094c2804681d500ae468984f29743867b2d34ee588 module=libcontainerd namespace=plugins.moby
Jan 15 14:00:29 balena balenad[686]: time="2019-01-15T14:00:29.370655020Z" level=warning msg="unknown container" container=d6498b06c6b3c7ccb84644094c2804681d500ae468984f29743867b2d34ee588 module=libcontainerd namespace=plugins.moby
Jan 15 14:00:29 balena balenad[686]: Removing stale PID file /var/run/messagebus.pid.
Jan 15 14:00:29 balena resin-supervisor[1202]: Removing stale PID file /var/run/messagebus.pid.
Jan 15 14:00:30 balena balenad[686]: Starting system message bus: dbus.
Jan 15 14:00:30 balena resin-supervisor[1202]: Starting system message bus: dbus.
Jan 15 14:00:30 balena balenad[686]: * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Jan 15 14:00:30 balena resin-supervisor[1202]: * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Jan 15 14:00:30 balena balenad[686]: ...done.
Jan 15 14:00:30 balena resin-supervisor[1202]: ...done.
Jan 15 14:01:48 balena balenad[686]: [2019-01-15T14:01:48.863Z] Event: Supervisor start {}
Jan 15 14:01:48 balena resin-supervisor[1202]: [2019-01-15T14:01:48.863Z] Event: Supervisor start {}
Jan 15 14:01:49 balena balenad[686]: [2019-01-15T14:01:49.004Z] Unmanaged Mode is set, skipping API client initialization
Jan 15 14:01:49 balena resin-supervisor[1202]: [2019-01-15T14:01:49.004Z] Unmanaged Mode is set, skipping API client initialization
Jan 15 14:01:52 balena balenad[686]: [2019-01-15T14:01:52.200Z] Starting up in unmanaged mode, activating local mode
Jan 15 14:01:52 balena resin-supervisor[1202]: [2019-01-15T14:01:52.200Z] Starting up in unmanaged mode, activating local mode
Jan 15 14:01:52 balena balenad[686]: [2019-01-15T14:01:52.680Z] Switching logging backend to LocalLogBackend
Jan 15 14:01:52 balena resin-supervisor[1202]: [2019-01-15T14:01:52.680Z] Switching logging backend to LocalLogBackend
Jan 15 14:01:53 balena balenad[686]: [2019-01-15T14:01:53.485Z] Reporting initial state, supervisor version and API info
Jan 15 14:01:53 balena resin-supervisor[1202]: [2019-01-15T14:01:53.485Z] Reporting initial state, supervisor version and API info
Jan 15 14:01:53 balena balenad[686]: [2019-01-15T14:01:53.951Z] Attempting to load preloaded apps...
Jan 15 14:01:53 balena resin-supervisor[1202]: [2019-01-15T14:01:53.951Z] Attempting to load preloaded apps...
Jan 15 14:01:54 balena balenad[686]: [2019-01-15T14:01:54.361Z] Starting API server
Jan 15 14:01:54 balena resin-supervisor[1202]: [2019-01-15T14:01:54.361Z] Starting API server
Jan 15 14:01:54 balena balenad[686]: [2019-01-15T14:01:54.482Z] Unmanaged Mode is set, skipping API binder initialization
Jan 15 14:01:54 balena resin-supervisor[1202]: [2019-01-15T14:01:54.482Z] Unmanaged Mode is set, skipping API binder initialization
Jan 15 14:01:54 balena balenad[686]: [2019-01-15T14:01:54.513Z] Applying target state
Jan 15 14:01:54 balena resin-supervisor[1202]: [2019-01-15T14:01:54.513Z] Applying target state
Jan 15 14:01:56 balena balenad[686]: [2019-01-15T14:01:56.121Z] Supervisor API listening on all interfaces
Jan 15 14:01:56 balena resin-supervisor[1202]: [2019-01-15T14:01:56.121Z] Supervisor API listening on all interfaces
Jan 15 14:01:59 balena balenad[686]: [2019-01-15T14:01:59.781Z] Event: Apply boot config in progress {}
Jan 15 14:01:59 balena resin-supervisor[1202]: [2019-01-15T14:01:59.781Z] Event: Apply boot config in progress {}
Jan 15 14:02:00 balena balenad[686]: [2019-01-15T14:02:00.183Z] Event: Apply boot config success {}
Jan 15 14:02:00 balena resin-supervisor[1202]: [2019-01-15T14:02:00.183Z] Event: Apply boot config success {}
Jan 15 14:02:03 balena balenad[686]: [2019-01-15T14:02:03.129Z] Event: Reboot {}
Jan 15 14:02:03 balena resin-supervisor[1202]: [2019-01-15T14:02:03.129Z] Event: Reboot {}
Jan 15 14:02:04 balena systemd[1]: Shutting down.
Jan 15 14:02:05 balena systemd[1]: Failed to set timeout to 600s: Invalid argument
Jan 15 14:02:05 balena kernel: systemd-shutdow: 29 output lines suppressed due to ratelimiting
