Our team has developed a container that uses a lot of RAM unfortunately it seems like the supervisor crashes and does not recover.
Supervisor: 9.14.6
balenaOS: 2.33.0
We are working with Orange Pis, I will try to replicate this issue on other devices as well…
Can you try enabling memory limits using mem_limit for your app container through the docker-compose file. Leaving about 300Megs for the OS/balena/supervisor as a starting point. And if you need more, you can try reducing until you get to a stable threshold perhaps?
Hi @torben what OS version are you testing this on? I just tested on my RPi3 running balenaOS 2.41 and it correctly shows the mem_limit set to 256mb in balena stats, see below. Perhaps if you are using an older OS version its possible that this was fixed in a new balena-engine version:
CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
02f74f26f597 bluetooth-audio_1449813_1045053 0.00% 9.734MiB / 256MiB 3.80% 0B / 0B 23.9MB / 12.3kB 12
15f5d2b8252e resin_supervisor 0.03% 32.13MiB / 475.9MiB 6.75% 0B / 0B 33.4MB / 109kB 13
