The Problem
I want to use Pyro4 for remote procedure calls across multiple containers using docker-compose. Currently, I am just trying to implement a simplified version of the Pyro4 warehouse example that I have setup to run on different machines, instead of the default localhost, since I am using multiple containers.
I can successfully start the Pyro name server in its own container, but in another container I can not publish the Warehouse class and start Pyro’s request loop. I am get the error OSError: [Errno 99] Cannot assign requested address
I imagine I am simply missing something in my docker-compose.yml file.
My attempt and additional information
I am using Host OS version balenaOS 2.46.1+rev1 and supervisor version 10.6.27, and deploying this to a Raspberry Pi 3 B+. I have a device variable “PYRO_HOST=pyro-ns” to set the address of the pyro name server.
I see the pyro name server get created
05.02.20 15:27:33 (-0500) pyro-ns Broadcast server running on 0.0.0.0:9091 05.02.20 15:27:33 (-0500) pyro-ns NS running on pyro-ns:9090 (172.17.0.3)
05.02.20 15:27:33 (-0500) pyro-ns Warning: HMAC key not set. Anyone can connect to this server!
05.02.20 15:27:33 (-0500) pyro-ns URI = PYRO:Pyro.NameServer@pyro-ns:9090
However, I am get the error OSError: [Errno 99] Cannot assign requested address
when I try to publish the Warehouse class and start Pyro’s request loop using
Pyro4.Daemon.serveSimple(
Warehouse: "example.warehouse"
ns=True, verbose=True)
I get the following
05.02.20 16:52:00 (-0500) container_B Traceback (most recent call last):
05.02.20 16:52:00 (-0500) container_B File "src/container_B_main.py", line 33, in <module>
05.02.20 16:52:00 (-0500) container_B main()
05.02.20 16:52:00 (-0500) container_B File "src/container_B_main.py", line 30, in main
05.02.20 16:52:00 (-0500) container_B ns=True, verbose=True)
05.02.20 16:52:00 (-0500) container_B File "/usr/local/lib/python3.5/site-packages/Pyro4/core.py", line 1204, in serveSimple
05.02.20 16:52:00 (-0500) container_B daemon = Daemon(host, port)
05.02.20 16:52:00 (-0500) container_B File "/usr/local/lib/python3.5/site-packages/Pyro4/core.py", line 1141, in __init__
05.02.20 16:52:00 (-0500) container_B self.transportServer.init(self, host, port, unixsocket)
05.02.20 16:52:00 (-0500) container_B File "/usr/local/lib/python3.5/site-packages/Pyro4/socketserver/threadpoolserver.py", line 134, in init
05.02.20 16:52:00 (-0500) container_B sslContext=sslContext)
05.02.20 16:52:00 (-0500) container_B File "/usr/local/lib/python3.5/site-packages/Pyro4/socketutil.py", line 298, in createSocket
05.02.20 16:52:00 (-0500) container_B bindOnUnusedPort(sock, bind[0])
05.02.20 16:52:00 (-0500) container_B File "/usr/local/lib/python3.5/site-packages/Pyro4/socketutil.py", line 542, in bindOnUnusedPort
05.02.20 16:52:00 (-0500) container_B sock.bind((host, 0))
05.02.20 16:52:00 (-0500) container_B OSError: [Errno 99] Cannot assign requested address
What am I missing that will allow Pyro to work across the multiple containers using docker-compose?
Following is my code:
docker-compose.yml
version: '2' services:
pyro-ns:
privileged: true
restart: always
build: ./pyro-ns
ports: - "9090:9090"
container_A:
privileged: true
restart: always
build: ./container_A
depends_on:
- pyro-ns
- container_B
container_B:
privileged: true
restart: always
build: ./container_B
depends_on:
- pyro-ns
pyro-ns
Dockerfile.template
FROM balenalib/%%BALENA_MACHINE_NAME%%-python:3-stretch-run
# enable container init system.
ENV INITSYSTEM on
# use `install_packages` if you need to install dependencies,
# for instance if you need git, just uncomment the line below.
# RUN install_packages git
RUN pip install --upgrade pip
RUN pip install Pyro4 dill
ENV PYRO_SERIALIZERS_ACCEPTED=serpent,json,marshal,pickle,dill
ENV PYTHONUNBUFFERED=0
CMD ["python", "-m", "Pyro4.naming"]
EXPOSE 9090
container_A
Dockerfile.template
ENV INITSYSTEM on
# Set our working directory
WORKDIR /usr/src/container_A
# Copy requirements.txt first for better cache on later pushes
COPY requirements.txt requirements.txt
# pip install python deps from requirements.txt on the resin.io build server
RUN pip install -r requirements.txt
# This will copy all files in our root to the working directory in the container
COPY . ./
# main.py will run when container starts up on the device
CMD ["python","-u","src/container_A_main.py"]
container_A_main.py
import Pyro4
import Pyro4.util
import sys
sys.excepthook = Pyro4.util.excepthook
try:
print('Top of container A')
warehouse = Pyro4.Proxy("PYRONAME:example.warehouse")
print('The warehouse contains: ', warehouse.list_contents())
except Exception as ex:
template = "An exception of type {0} occurred. Arguments:\n{1!r}"
message = template.format(type(ex).__name__, ex.args)
print(message)
container_B
Dockerfile.template
ENV INITSYSTEM on
WORKDIR /usr/src/container_B
COPY . ./
CMD ["python","-u","src/container_B_main.py"]
container_B_main.py
from __future__ import print_function
import Pyro4
@Pyro4.expose
@Pyro4.behavior(instance_mode="single")
class Warehouse(object):
def __init__(self):
self.contents = ["chair", "bike", "flashlight", "laptop", "couch"]
def list_contents(self):
return self.contents
def take(self, name, item):
self.contents.remove(item)
print("{0} took the {1}.".format(name, item))
def store(self, name, item):
self.contents.append(item)
print("{0} stored the {1}.".format(name, item))
def main():
if __name__ == "__main__":
main()
For both container_A and container_B the requirements.txt file is the same.
requirements.txt
`Pyro4`
