So I am using a HiFiBerry DAC+ ADC Pro and it works great for sound output. I have it configured with the btoverlay of “hifiberry-dacplusadcpro”.
So now I am attempting to I am attempting to I am attempting to I am attempting to I am attempting to I am attempting to I am attempting to connect my chromecast audio through the soundcard input.
The issue I am encountering is when I add the variable “SOUND_ENABLE_SOUNDCARD_INPUT” errors appear in the logs, specifically related to pulseaudio but the multiroom-server is also throwing errors (probably related to the pulseaudio issues).
multiroom-server
multiroom-server --- Multiroom ---
multiroom-server Starting multiroom service with settings:
multiroom-server - Mode: server
multiroom-server - Snapcast version: v0.25.0
multiroom-server Starting multi-room server...
multiroom-server 2022-02-14 23-41-47.877 [Error] (Avahi) Failed to create client: Daemon not running
multiroom-client 2022-02-14 23-41-48.276 [Error] (Controller) Failed to send hello request, error: Operation timed out
multiroom-client 2022-02-14 23-41-48.277 [Error] (Controller) Time sync request failed: Operation timed out
multiroom-client 2022-02-14 23-41-48.277 [Error] (Connection) Error reading message header of length 0: Operation canceled
sound-supervisor Joining the fleet, requesting master info with fleet-sync...
multiroom-client metadata:{"STREAM":"balenaSound"}
multiroom-server 2022-02-14 23-41-49.322 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
multiroom-server 2022-02-14 23-41-49.323 [Error] (StreamSession) StreamSession write error (msg length: 0): Broken pipe
multiroom-server 2022-02-14 23-41-49.323 [Error] (StreamSessionTCP) Error in socket shutdown: Socket not connected
audio E: [pulseaudio] backend-native.c: socket(SEQPACKET, SCO) Address family not supported by protocol
bluetooth - Successfully connected to Pixel 5a (xxxxxxxx)...
audio E: [pulseaudio] backend-native.c: accept(): Not a socket
audio W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
audio W: [pulseaudio] module-loopback.c: Cannot set requested sink latency of 66.67 ms, adjusting to 250.00 ms
audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 250.00 ms
multiroom-server 2022-02-14 23-42-03.251 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
multiroom-server 2022-02-14 23-42-11.839 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
multiroom-server 2022-02-14 23-42-11.896 [Error] (StreamSessionTCP) Error reading message header of length 0: Connection reset by peer
multiroom-server 2022-02-14 23-42-11.897 [Error] (StreamSessionTCP) Error in socket shutdown: Socket not connected
Attaching a screen shot to show the Device Variables as I am unsure if I have added “SOUND_ENABLE_SOUNDCARD_INPUT” correctly.
Does anyone have any ideas?
