I’m looking for a way to use D-BUS and access the Network Manager to determine if eth0 is using DHCP or not. Later I want to set dhcp/static (and ip, etc), but first task is to just determine if eth0 is set up for static IP or dhcp. I can read the other settings like the gateway, address, netmask, but I can’t find a setting for DHCP. Anyone have an example on how to get the dhcp status property? The documentation seems to indicate there should be a method property under the Ipv4Config, but it doesn’t seem to exist.
I know it’s been a while, and you’ve probably found a better solution (by using nmcli or something).
But I did want to respond with what I’ve found for whoever might be interested.
Convenience var:
DEFAULT_SEND="dbus-send --system --print-reply --reply-timeout=1000"
DEFAULT_METHOD="${DEFAULT_SEND} --type=method_call"
First to find the correct device:
root@balena4:/usr/src/app# $DEFAULT_METHOD --dest='org.freedesktop.NetworkManager' '/org/freedesktop/NetworkManager' 'org.freedesktop.NetworkManager.GetDeviceByIpIface' string:'eth0'
method return time=1676401690.826238 sender=:1.5 -> destination=:1.110 serial=8780 reply_serial=2
object path "/org/freedesktop/NetworkManager/Devices/2"
And then to find the connection settings:
root@balena4:/usr/src/app# $DEFAULT_METHOD --dest='org.freedesktop.NetworkManager' '/org/freedesktop/NetworkManager/Devices/2' 'org.freedesktop.NetworkManager.Device.GetAppliedConnection' uint32:0
method return time=1676402023.429151 sender=:1.5 -> destination=:1.115 serial=9240 reply_serial=2
array [
dict entry(
string "connection"
array [
dict entry(
string "autoconnect-priority"
variant int32 -999
dict entry(
string "id"
variant string "Wired connection 1"
dict entry(
string "interface-name"
variant string "eth0"
dict entry(
string "permissions"
variant array [
dict entry(
string "timestamp"
variant uint64 1675796408
dict entry(
string "type"
variant string "802-3-ethernet"
dict entry(
string "uuid"
variant string "8ffa7d04-db48-3271-8fbc-4cca019f2190"
dict entry(
array [
dict entry(
string "auto-negotiate"
variant boolean false
dict entry(
string "mac-address-blacklist"
variant array [
dict entry(
string "s390-options"
variant array [
dict entry(
string "ipv4"
array [
dict entry(
string "address-data"
variant array [
dict entry(
string "addresses"
variant array [
dict entry(
string "dns-search"
variant array [
dict entry(
string "method"
variant string "auto"
dict entry(
string "route-data"
variant array [
dict entry(
string "routes"
variant array [
dict entry(
string "ipv6"
array [
dict entry(
variant array [
dict entry(
string "addresses"
variant array [
dict entry(
string "dns-search"
variant array [
dict entry(
string "method"
dict entry(
string "route-data"
variant array [
dict entry(
string "routes"
variant array [
dict entry(
string "proxy"
array [
uint64 1
As you can see, this returns the used connection settings.
The entry you’re interested in here is ipv4.method.
The Settings object has a method that you can use to change these fields.
Thanks for these details! No, I haven’t solved it yet, I will try this approach and report back, thanks!
Took a while before I got to test this out. It worked great, so the key was to get the “applied connection” and the ipv4/method property was present there.
Glad to hear it worked out for you ![]()
