Use HID device inside container
We’re trying to use a HID device inside a container.
Inside the container we can see it using dmesg:
usb 1-2: USB disconnect, device number 7
usb 1-2: new low-speed USB device number 8 using xhci_hcd
hid-generic 0003:07F2:0003.0006: hiddev96,hidraw0: USB HID v1.11 Device [Microcomputer Applications, Inc. KEYLOK HID Mode Dongle] on usb-0000:00:14.0-2/input0
On the host OS we can see it:
root@82ea18a:~# ls /dev/usb
hiddev0
But inside the container we do not see it:
root@3ce553889123:~# ls /dev/usb
ls: cannot access /dev/usb: No such file or directory
I also tried udevd & and udevadm trigger, but that did not work either.
From the docs:
Only support short syntax and named volumes. Bind mounts are not supported, except for as allowed by resin.io specific labels
Ideally I would like to something like this I guess?
volumes:
  - /dev/usb:/dev/usb
How should we do this?
Update: this is fixed by setting priviliged to true in the docker-compose file.
