I’m connecting an external hard disk to my Pi 3. The disk is formatted as “Mac OS Extended”, also known as HFS+ which my container has the appropriate drivers to use. A SO answer wants me to use the device flag when executing docker run, how do I customize this using resin
Docker supports adding/passing through devices to a container:
docker run --device=/dev/sdb
– Stack Overflow
