I built a release that became corrupt. Now, I can’t delete this release and also can not build a new one from the same repo. Please delete this release. I will grant access to Balena support.
Currently it’s not allowed to delete releases, but you can invalidate it if you no longer want it available. You should be able to generate a new one in any case. Why do you say you can’t build one?
Thanks for your advise but I already deleted it.
Hi, could you clarify what you mean when you say that you deleted a release? As Rafael mentioned, we can only invalidate releases, not delete them. Did you mean deleting the device?
Hi, I mean: I deleted the release, not the device! See here: How to delete a release?
Aaah ok, apologies. I see what you mean now. Thank you for the clarification!
