Updating Open-Balena Versions
Is it possible to merge one of the PR’s in open balena that bumps the Versions on the balena dependencies for the quickstart? also write a script to update an older open balena to the new versions?
https://github.com/balena-io/open-balena/pull/185
https://github.com/balena-io/open-balena/pull/168
at the moment if you follow the quickstart guide, there’s been so many breaking changes pushed to the dependencies and balena-cli that a modern version of balena-cli will not work with the current open-balena quickstart.
If you look at the 2nd PR that’s been sitting unmerged for almost a whole year, and it’s a simple dependency bump…
