I am new on docker with raspberry pi. I just write a “Dockerfile” to start to build the first project. However, I get lots of shit in the beginning.
The first issues is unable to use multiple --build-arg to build it. I seen the similar issues. Currently, I reduce only one --build-arg flag to build and it get started.
But, the second matter is on “RUN apt-get install package”. I cut the phrase of error to paste here. It seems the matter on network.
Err http://archive.raspbian.org jessie InRelease
Err http://archive.raspberrypi.org jessie InRelease
Err http://archive.raspbian.org jessie Release.gpg
Unable to connect to 221.156.247.212:8080:
Err http://archive.raspberrypi.org jessie Release.gpg
Reading package lists...
W: Failed to fetch http://archive.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/InRelease
W: Failed to fetch http://archive.raspbian.org/raspbian/dists/jessie/Release.gpg Unable to connect to 221.156.247.212:8080:
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/Release.gpg Unable to connect to 221.156.247.212:8080:
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
E: Unable to locate package upgrade
I run on raspberry 1B+ with docker image-“resin/raspberry-pi-debian:latest”.
This is the output of “docker info”. Wish some help. Thanks.
Containers: 1
Running: 0
Paused: 0
Stopped: 1
Images: 17
Server Version: 18.05.0-ce
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
Volume: local
Network: bridge host macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file logentries splunk syslog
Swarm: inactive
Runtimes: runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 773c489c9c1b21a6d78b5c538cd395416ec50f88
runc version: 4fc53a81fb7c994640722ac585fa9ca548971871
init version: 949e6fa
Security Options:
seccomp
Profile: default
Kernel Version: 4.14.30+
Operating System: Raspbian GNU/Linux 9 (stretch)
OSType: linux
Architecture: armv6l
CPUs: 1
Total Memory: 243.5MiB
Docker Root Dir: /var/lib/docker
Debug Mode (client): false
Debug Mode (server): false
Registry: https://index.docker.io/v1/
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
WARNING: No memory limit support
WARNING: No swap limit support
WARNING: No kernel memory limit support
WARNING: No oom kill disable support
WARNING: No cpu cfs quota support
WARNING: No cpu cfs period support
WARNING: No cpuset support
