Hi all,
Note:
I posted this in the Product support category but I think it belongs here. The other post will be deleted
I’am just getting started on Balena here. Using BalenaCloud and the BalenaCLI on my Mac to get the files together and push this to builder to create the images. I made a post before but I sort of hijacked my own post as I did come up with more questions so this new post seemed more prudent.
My idea was to make a generic image for some RPIs, while they not all need the same apps running as they have slightly different purposes. So I can just run the apps I need. This way, I have one fleet with 3 to 5 devices. Otherwise, I need to make more fleets as each RPI has differs slightly and requires slightly different apps to run (let me know if this would be a better approach then my thought).
I tried following the tutorial on this blogpost. This one seems heavily outdated though. When composing the one docker-compose.yml file from merging the two apps named in the description, I noticed in the two original yml-files there is on both of them a section with hostname. This is not mentioned in the blogpost.
Further more, when I merge the apps, I don’t get the containers hostname, multiroom-client and multiroom-server up and running at all. The container sound-supervisor does get up and running but displays a lot of errors.
Sound-supervisor errors
sound-supervisor > sound-supervisor@1.0.1 start /usr/src
sound-supervisor > node build/index.js
sound-supervisor
sound-supervisor internal/fs/utils.js:332
sound-supervisor throw err;
sound-supervisor ^
sound-supervisor
sound-supervisor Error: ENOENT: no such file or directory, open 'VERSION'
sound-supervisor at Object.openSync (fs.js:498:3)
sound-supervisor at Object.readFileSync (fs.js:394:35)
sound-supervisor at Object.<anonymous> (/usr/src/build/SoundAPI.js:10:20)
sound-supervisor at Module._compile (internal/modules/cjs/loader.js:1114:14)
sound-supervisor at Object.Module._extensions..js (internal/modules/cjs/loader.js:1143:10)
sound-supervisor at Module.load (internal/modules/cjs/loader.js:979:32)
sound-supervisor at Function.Module._load (internal/modules/cjs/loader.js:819:12)
sound-supervisor at Module.require (internal/modules/cjs/loader.js:1003:19)
sound-supervisor at require (internal/modules/cjs/helpers.js:107:18)
sound-supervisor at Object.<anonymous> (/usr/src/build/index.js:5:20) {
sound-supervisor errno: -2,
sound-supervisor syscall: 'open',
sound-supervisor code: 'ENOENT',
sound-supervisor path: 'VERSION'
sound-supervisor }
sound-supervisor npm ERR! code ELIFECYCLE
sound-supervisor npm ERR! errno 1
sound-supervisor npm ERR! sound-supervisor@1.0.1 start: `node build/index.js`
sound-supervisor npm ERR! Exit status 1
sound-supervisor npm ERR! Failed at the sound-supervisor@1.0.1 start script.
sound-supervisor npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
sound-supervisor
sound-supervisor npm ERR! A complete log of this run can be found in:
sound-supervisor npm ERR! /root/.npm/_logs/2024-08-29T14_03_28_280Z-debug.log
sound-supervisor
sound-supervisor
sound-supervisor
sound-supervisor ^
sound-supervisor
sound-supervisor }
sound-supervisor
sound-supervisor npm ERR! /root/.npm/_logs/2024-08-29T14_04_23_580Z-debug.log
Before I can get a look at the logs it mentions in the error message, the container restarts so a SSH connection is lost and re-established but that all goes too quick to extract the log and it’s content.
Further, if I go to the ip-address of my Raspberry Pi in a browser, I get a 403 error. I am expecting to see at least either Pihole or Balena-sound-dashboard. Constructing an image with purely balena-sound or balena-pihole works without any errors.
I thought if I figure this all out, I have a good base in doing my own setup afterwards. So any help would be appreciated!
For reference:
docker-compose.yml merged apps (the one I created)
version: "2"
volumes:
spotifycache:
pihole_config:
dnsmasq_config:
tailscale:
services:
audio:
build: ./core/audio
privileged: true
labels:
io.balena.features.dbus: 1
ports:
- 4317:4317
sound-supervisor:
build:
context: .
dockerfile: ./core/sound-supervisor/Dockerfile.template
network_mode: host
labels:
io.balena.features.balena-api: "1"
io.balena.features.supervisor-api: 1
multiroom-server:
build: ./core/multiroom/server
restart: on-failure
ports:
- 1704:1704
- 1705:1705
- 1780:1780
multiroom-client:
build: ./core/multiroom/client
restart: on-failure
# Plugins
# -- Additional plugins can be added. See https://balena-sound.pages.dev/plugins
# -- Remove unwanted plugins as needed
bluetooth:
build: ./plugins/bluetooth
restart: on-failure
network_mode: host
cap_add:
- NET_ADMIN
labels:
airplay:
build: ./plugins/airplay
restart: on-failure
network_mode: host
privileged: true
labels:
spotify:
build: ./plugins/spotify
restart: on-failure
privileged: true
network_mode: host
volumes:
- spotifycache:/var/cache/raspotify
#Pihole stuff
pihole:
build: ./balena-pihole/pihole
cap_add:
- SYS_TTY_CONFIG
- NET_ADMIN
volumes:
- "pihole_config:/etc/pihole"
- "dnsmasq_config:/etc/dnsmasq.d"
dns:
- "127.0.0.1"
- "1.1.1.1"
network_mode: host
labels:
io.balena.features.dbus: "1"
devices:
- /dev/tty0
- /dev/tty1
tmpfs:
- /var/log/pihole
environment:
DNSMASQ_LISTENING: all
PIHOLE_DNS_: 1.1.1.1;1.0.0.1
FONTFACE: Terminus
FONTSIZE: 8x14
WEBPASSWORD: balena
VIRTUAL_HOST: balena-devices.com
WEB_BIND_ADDR: 0.0.0.0
unbound:
build: ./balena-pihole/unbound
cap_add:
- NET_ADMIN
ports:
- "5053:5053/tcp"
- "5053:5053/udp"
fbcp:
image: bh.cr/balenalabs/fbcp/1.0.4
privileged: true
hostname:
image: bh.cr/g_tomas_migone1/hostname-rpi/0.2.1
restart: no
labels:
environment:
SET_HOSTNAME: pihole
tailscale:
image: tailscale/tailscale:v1.72.1@sha256:83a6faec34866f70914a7d241d6ca749e6914f08f4f9059d942e1c3088dc001b
restart: unless-stopped
environment:
TS_STATE_DIR: /var/lib/tailscale
TS_SOCKET: /var/run/tailscale/tailscaled.sock
TS_USERSPACE: false
TS_AUTH_ONCE: false
TS_HOSTNAME: pi-hole
TS_EXTRA_ARGS: --accept-dns=false --reset
network_mode: host
cap_add:
- NET_ADMIN
- NET_RAW
- SYS_MODULE
labels:
io.balena.features.kernel-modules: 1
tmpfs:
- /tmp
- /run
volumes:
- tailscale:/var/lib/tailscale
entrypoint:
- /bin/sh
- -c
command:
modprobe tun || true
modprobe wireguard || true
mkdir -p /dev/net
[ ! -c /dev/net/tun ] && mknod /dev/net/tun c 10 200
/usr/local/bin/containerboot
Original docker-compose.yml balena-sound
version: "2"
volumes:
spotifycache:
services:
# Core services
# -- Required for a fully featured installation of balenaSound
# -- Mutiroom services can be removed if not using multiroom mode
audio:
build: ./core/audio
privileged: true
labels:
ports:
- 4317:4317
sound-supervisor:
build:
context: .
network_mode: host
labels:
multiroom-server:
restart: on-failure
ports:
- 1704:1704
- 1705:1705
- 1780:1780
multiroom-client:
restart: on-failure
# Plugins
bluetooth:
restart: on-failure
network_mode: host
cap_add:
- NET_ADMIN
labels:
airplay:
restart: on-failure
network_mode: host
privileged: true
labels:
spotify:
restart: on-failure
privileged: true
network_mode: host
volumes:
# https://github.com/balenablocks/hostname
hostname:
build: ./core/hostname
restart: no
labels:
environment:
SET_HOSTNAME: balena
Original docker-compose.yml balena-pihole
version: "2.1"
volumes:
pihole_config: {}
dnsmasq_config: {}
tailscale: {}
services:
pihole:
build: pihole
cap_add:
- SYS_TTY_CONFIG
- NET_ADMIN
volumes:
dns:
- "127.0.0.1"
- "1.1.1.1"
network_mode: host
labels:
devices:
- /dev/tty0
- /dev/tty1
tmpfs:
- /var/log/pihole
environment:
FONTFACE: Terminus
FONTSIZE: 8x14
WEBPASSWORD: balena
unbound:
build: unbound
cap_add:
- NET_ADMIN
ports:
- "5053:5053/tcp"
- "5053:5053/udp"
# https://github.com/balena-labs-projects/fbcp
# https://hub.balena.io/blocks/1792683/fbcp
fbcp:
privileged: true
# https://hub.balena.io/blocks/1918776/hostname-rpi
hostname:
restart: no
labels:
environment:
# https://hub.docker.com/r/tailscale/tailscale
# https://github.com/tailscale/tailscale/blob/main/cmd/containerboot/main.go
# https://tailscale.com/kb/1282/docker
# https://tailscale.com/kb/1278/tailscaled
# https://tailscale.com/kb/1241/tailscale-up
# https://tailscale.com/kb/1242/tailscale-serve
# https://tailscale.com/kb/1311/tailscale-funnel
tailscale:
environment:
TS_USERSPACE: false
TS_AUTH_ONCE: false
network_mode: host
cap_add:
- NET_ADMIN
- NET_RAW
- SYS_MODULE
labels:
tmpfs:
- /tmp
- /run
volumes:
entrypoint:
- /bin/sh
- -c
command:
mkdir -p /dev/net
