When I try armv7l, I get the following, which seems like a lot of successful building followed by a failure to package, trying to run an x86 version of fpm on an arm machine.
pi@pi4:~/Documents/etcher $ ./node_modules/.bin/electron-builder --armv7l --linux deb
Configuring yargs through package.json is deprecated and will be removed in the next major release, please use the JS API instead.
• electron-builder version=20.40.2
• loaded configuration file=/home/pi/Documents/etcher/electron-builder.yml
• writing effective config file=dist/builder-effective-config.yaml
• executing node-gyp rebuild arch=armv7l
• rebuilding native production dependencies platform=linux arch=armv7l
• packaging platform=linux arch=armv7l electron=3.1.9 appOutDir=dist/linux-armv7l-unpacked
• building target=deb arch=armv7l file=dist/balena-etcher_1.5.60_armv7l.deb
Error: Exit code: 1. Command failed: /home/pi/.cache/electron-builder/fpm/fpm-1.9.3-2.3.1-linux-x86/fpm -s dir -t deb --architecture armv7l --name balena-etcher --force --after-install /tmp/t-Bew2la/0-after-install --after-remove /tmp/t-Bew2la/1-after-remove --description balenaEtcher is a powerful OS image flasher built with web technologies to ensure flashing an SDCard or USB drive is a pleasant and safe experience. It protects you from accidentally writing to your hard-drives, ensures every byte of data was written correctly and much more.
Flash OS images to SD cards and USB drives, safely and easily. --version 1.5.60 --package /home/pi/Documents/etcher/dist/balena-etcher_1.5.60_armv7l.deb --maintainer Balena Inc. <hello@etcher.io> --url https://github.com/balena-io/etcher --vendor Balena Inc. <hello@etcher.io> --category utils --deb-compression xz --deb-priority optional --depends gconf2 --depends gconf-service --depends libappindicator1 --depends libasound2 --depends libatk1.0-0 --depends libc6 --depends libcairo2 --depends libcups2 --depends libdbus-1-3 --depends libexpat1 --depends libfontconfig1 --depends libfreetype6 --depends libgcc1 --depends libgconf-2-4 --depends libgdk-pixbuf2.0-0 --depends libglib2.0-0 --depends libgtk-3-0 --depends liblzma5 --depends libnotify4 --depends libnspr4 --depends libnss3 --depends libpango1.0-0 --depends libstdc++6 --depends libx11-6 --depends libxcomposite1 --depends libxcursor1 --depends libxdamage1 --depends libxext6 --depends libxfixes3 --depends libxi6 --depends libxrandr2 --depends libxrender1 --depends libxss1 --depends libxtst6 --depends polkit-1-auth-agent | policykit-1-gnome | polkit-kde-1 --license Apache-2.0 /home/pi/Documents/etcher/dist/linux-armv7l-unpacked/=/opt/balenaEtcher /home/pi/Documents/etcher/assets/iconset/16x16.png=/usr/share/icons/hicolor/16x16/apps/balena-etcher-electron.png /home/pi/Documents/etcher/assets/iconset/32x32.png=/usr/share/icons/hicolor/32x32/apps/balena-etcher-electron.png /home/pi/Documents/etcher/assets/iconset/48x48.png=/usr/share/icons/hicolor/48x48/apps/balena-etcher-electron.png /home/pi/Documents/etcher/assets/iconset/128x128.png=/usr/share/icons/hicolor/128x128/apps/balena-etcher-electron.png /home/pi/Documents/etcher/assets/iconset/256x256.png=/usr/share/icons/hicolor/256x256/apps/balena-etcher-electron.png /home/pi/Documents/etcher/assets/iconset/512x512.png=/usr/share/icons/hicolor/512x512/apps/balena-etcher-electron.png /tmp/t-Bew2la/2-balenaEtcher.desktop=/usr/share/applications/balena-etcher-electron.desktop
/home/pi/.cache/electron-builder/fpm/fpm-1.9.3-2.3.1-linux-x86/lib/ruby/bin/ruby: line 6: /home/pi/.cache/electron-builder/fpm/fpm-1.9.3-2.3.1-linux-x86/lib/ruby/bin.real/ruby: cannot execute binary file: Exec format error
/home/pi/.cache/electron-builder/fpm/fpm-1.9.3-2.3.1-linux-x86/lib/ruby/bin/ruby: line 6: /home/pi/.cache/electron-builder/fpm/fpm-1.9.3-2.3.1-linux-x86/lib/ruby/bin.real/ruby: Success
at /home/pi/Documents/etcher/node_modules/builder-util/src/util.ts:126:16
at ChildProcess.exithandler (child_process.js:301:5)
at ChildProcess.emit (events.js:189:13)
at maybeClose (internal/child_process.js:970:16)
at Socket.stream.socket.on (internal/child_process.js:389:11)
at Socket.emit (events.js:189:13)
at Pipe._handle.close (net.js:600:12)
From previous event:
at FpmTarget.build (/home/pi/Documents/etcher/node_modules/app-builder-lib/src/targets/fpm.ts:93:44)
at /home/pi/Documents/etcher/node_modules/app-builder-lib/src/platformPackager.ts:131:24
at AsyncTaskManager.add (/home/pi/Documents/etcher/node_modules/builder-util/src/asyncTaskManager.ts:14:20)
at LinuxPackager.packageInDistributableFormat (/home/pi/Documents/etcher/node_modules/app-builder-lib/src/platformPackager.ts:123:17)
at /home/pi/Documents/etcher/node_modules/app-builder-lib/src/platformPackager.ts:114:10
at Generator.next (<anonymous>)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at LinuxPackager.pack (/home/pi/Documents/etcher/node_modules/app-builder-lib/src/platformPackager.ts:111:95)
at /home/pi/Documents/etcher/node_modules/app-builder-lib/src/packager.ts:430:24
at xfs.stat (/home/pi/Documents/etcher/node_modules/fs-extra-p/node_modules/fs-extra/lib/mkdirs/mkdirs.js:56:16)
at /home/pi/Documents/etcher/node_modules/graceful-fs/polyfills.js:285:20
at FSReqWrap.oncomplete (fs.js:155:5)
at Packager.doBuild (/home/pi/Documents/etcher/node_modules/app-builder-lib/src/packager.ts:396:24)
at /home/pi/Documents/etcher/node_modules/app-builder-lib/src/packager.ts:366:57
at /home/pi/Documents/etcher/node_modules/graceful-fs/graceful-fs.js:111:16
at /home/pi/Documents/etcher/node_modules/graceful-fs/graceful-fs.js:45:10
at FSReqWrap.oncomplete (fs.js:141:20)
at Packager._build (/home/pi/Documents/etcher/node_modules/app-builder-lib/src/packager.ts:335:133)
at /home/pi/Documents/etcher/node_modules/app-builder-lib/src/packager.ts:331:23
at Packager.build (/home/pi/Documents/etcher/node_modules/app-builder-lib/src/packager.ts:288:14)
at build (/home/pi/Documents/etcher/node_modules/app-builder-lib/src/index.ts:59:28)
at build (/home/pi/Documents/etcher/node_modules/electron-builder/src/builder.ts:228:10)
at then (/home/pi/Documents/etcher/node_modules/electron-builder/src/cli/cli.ts:46:19)
I’ve asked for help with this on the Raspberry Pi forum - perhaps they can help me get a working fpm installed, and then I can get back here to continue the build, trying @shaunmulligan’s tip about pointing to a local fpm.
Hello everyone,
It seems that another user successfully built a debian package for rpi4, you can check the forum thread here @futurejones If you’re willing to give some feedback about the issues you encountered and how you overcame them, even if they made you switch to another path, that would be highly appreciated so we can hopefully enhance the documentation with the missing pieces and/or investigate more!
Now trying the workaround to use the native fpm, that @shaunmulligan suggested:
USE_SYSTEM_FPM="true" ./node_modules/.bin/electron-builder --armv7l --linux deb
pi@pi4:~/Documents/etcher $ USE_SYSTEM_FPM="true" ./node_modules/.bin/electron-builder --armv7l --linux deb
│ Update available 20.40.2 → 22.1.0 │
│ Run yarn upgrade electron-builder to update │
Installing /var/cache/apt/archives/partial/balena-etcher_1.5.60_armv7l.deb
tar: Archive is compressed. Use -J option
tar: Error is not recoverable: exiting now
dpkg-deb: error: tar subprocess returned error exit status 2
dpkg: error processing archive /var/cache/apt/archives/partial/balena-etcher_1.5.60_armv7l.deb (--install):
dpkg-deb --control subprocess returned error exit status 2
Errors were encountered while processing:
fix by rolling back fpm to 1.10.2
see https://stackoverflow.com/questions/17026441/how-to-install-a-specific-version-of-a-ruby-gem#17026442
gem uninstall fpm
gem install fpm -v 1.10.2
That builds OK (but so did the newer fpm, it just wouldn’t install!)
│ Update available 20.40.2 → 21.2.0 │
Well, that gets farther, at least it doesn’t complain as it did before. But…
pi@pi4:~/Documents/etcher/dist $ sudo apt install /var/cache/apt/archives/partial/balena-etcher_1.5.60_armv7l.deb
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'balena-etcher:armv7l' instead of '/var/cache/apt/archives/partial/balena-etcher_1.5.60_armv7l.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
balena-etcher:armv7l : Depends: libappindicator1:armv7l but it is not installable
Depends: libasound2:armv7l but it is not installable
Depends: libatk1.0-0:armv7l but it is not installable
Depends: libc6:armv7l but it is not installable
Depends: libcairo2:armv7l but it is not installable
Depends: libcups2:armv7l but it is not installable
Depends: libdbus-1-3:armv7l but it is not installable
Depends: libexpat1:armv7l but it is not installable
Depends: libfontconfig1:armv7l but it is not installable
Depends: libfreetype6:armv7l but it is not installable
Depends: libgcc1:armv7l but it is not installable
Depends: libgconf-2-4:armv7l but it is not installable
Depends: libgdk-pixbuf2.0-0:armv7l but it is not installable
Depends: libglib2.0-0:armv7l but it is not installable
Depends: libgtk-3-0:armv7l but it is not installable
Depends: liblzma5:armv7l but it is not installable
Depends: libnotify4:armv7l but it is not installable
Depends: libnspr4:armv7l but it is not installable
Depends: libnss3:armv7l but it is not installable
Depends: libpango1.0-0:armv7l but it is not installable
Depends: libstdc++6:armv7l but it is not installable
Depends: libx11-6:armv7l but it is not installable
Depends: libxcomposite1:armv7l but it is not installable
Depends: libxcursor1:armv7l but it is not installable
Depends: libxdamage1:armv7l but it is not installable
Depends: libxext6:armv7l but it is not installable
Depends: libxfixes3:armv7l but it is not installable
Depends: libxi6:armv7l but it is not installable
Depends: libxrandr2:armv7l but it is not installable
Depends: libxrender1:armv7l but it is not installable
Depends: libxss1:armv7l but it is not installable
Depends: libxtst6:armv7l but it is not installable
E: Unable to correct problems, you have held broken packages.
pi@pi4:~/Documents/etcher/dist $ sudo dpkg -i balena-etcher_1.5.60_armv7l.deb
dpkg: error processing archive balena-etcher_1.5.60_armv7l.deb (--install):
package architecture (armv7l) does not match system (armhf)
After trying many different build combinations, including writing my own packaging script, I have found the following to be the most reliable and consistent method of building Etcher. This method has been tested on a fresh install of Raspbian Buster on a Raspberry Pi 4.
git clone --recursive https://github.com/balena-io/etcher
cd etcher
git checkout v1.5.63
Install Requirements
pip install -r requirements.txt
Setup and Install NPM Modules .
make electron-develop
At this point you should be able to run a test of Etcher with -
npm start
Patch Build Files
# disable tiffutil in the Makefile as this is a Mac only app and will cause the build to fail
sed -i 's/tiffutil/#tiffutil/g' Makefile
# restrict output to .deb package only to save build time
sed -i 's/TARGETS="deb rpm appimage"/TARGETS="deb"/g' scripts/resin/electron/build.sh
Build and Package
# use USE_SYSTEM_FPM="true" to force the use of the installed FPM version
USE_SYSTEM_FPM="true" make electron-build
Install Package
# *.deb package will be in /etcher/dist/*
# filename will depend on which release version was checked out
sudo apt-get install ./dist/balena-etcher-electron_1.5.63+a1558116_armv7l.deb
Note: You can ignore the chmod: cannot access '/opt/balenaEtcher/chrome-sandbox': No such file or directory warning. It is caused by the postinst file and is only relevant for electron versions 5+.
FYI: @futurejones has a github site where he’s got the whole Etcher-on-a-Pi process nailed, and where he provides some easy scripts : install_dependencies, build, and package_etcher. See here.
The Raspberry Pi 4 is the successor to the Raspberry Pi 3. It builds upon the Pi 3 by upgrading the ARM cores to Cortex-A72, offering up to 4GB RAM, USB 3.0, and gigabit ethernet.
I did see mention of an A71, in the threads below, but not a 72? IMHO this device was released working on Raspbian, but somehow “green” Just the issues app developers are having with it. Octoprint barely works on a Pi4, for example.
I’m not a code jock, but I see known inconsistencies. x86 Architecture is a CISC (inline construction set chip. The ARM 64 chip is a true RISC chip (reduced instruction set chip) aka parallel processing. It is more of the “Alpha” “Power” “Itanium” “Sun” series of chips. The fact that ARM servers are replacing CISC servers, for untethered parallel processing power, is not to be overlooked. I’m just pointing out these things, porting from one chip architecture to another.
That’s why the original Power Macs were such screamers. Parallel processing. The fact they ran MS Office (but the highest base of installed versions of MS Office) Still MS was a CISC company. Pushing to all PC/x86 manufacturers. But Mac is what kept them alive.
I digress… These are things to truly consider when porting across architectures. Not known to be a piece of cake. We just all have access to the tools today. But what did the Alpha, Itanium & Power programmers really do to port NT4-5 to their platforms? Privately own software originally developed for VMS. AKA Posix. Posix is still in Win.xxx today.
Another case of Mr. Gates silently slipping someone else’s code under his arm.
