Sure! The dates line up with my observations. There aren’t any log entries that I can see around the time the restarts start to happen (repeated udev* lines) due to my dead man switch.
[Mon Apr 20 21:10:59 2020] Booting Linux on physical CPU 0x0
[Mon Apr 20 21:10:59 2020] Linux version 4.14.53+ (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Thu Mar 12 08:44:21 UTC 2020
[Mon Apr 20 21:10:59 2020] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[Mon Apr 20 21:10:59 2020] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[Mon Apr 20 21:10:59 2020] OF: fdt: Machine model: TI AM335x BeagleBone Green Wireless
[Mon Apr 20 21:10:59 2020] Memory policy: Data cache writeback
[Mon Apr 20 21:10:59 2020] efi: Getting EFI parameters from FDT:
[Mon Apr 20 21:10:59 2020] efi: UEFI not found.
[Mon Apr 20 21:10:59 2020] cma: Reserved 48 MiB at 0x9c800000
[Mon Apr 20 21:10:59 2020] On node 0 totalpages: 130560
[Mon Apr 20 21:10:59 2020] free_area_init_node: node 0, pgdat c19d7540, node_mem_map df961000
[Mon Apr 20 21:10:59 2020] Normal zone: 1148 pages used for memmap
[Mon Apr 20 21:10:59 2020] Normal zone: 0 pages reserved
[Mon Apr 20 21:10:59 2020] Normal zone: 130560 pages, LIFO batch:31
[Mon Apr 20 21:10:59 2020] CPU: All CPU(s) started in SVC mode.
[Mon Apr 20 21:10:59 2020] AM335X ES2.1 (sgx neon)
[Mon Apr 20 21:10:59 2020] random: get_random_bytes called from start_kernel+0xac/0x45c with crng_init=0
[Mon Apr 20 21:10:59 2020] percpu: Embedded 18 pages/cpu @df928000 s41612 r8192 d23924 u73728
[Mon Apr 20 21:10:59 2020] pcpu-alloc: s41612 r8192 d23924 u73728 alloc=18*4096
[Mon Apr 20 21:10:59 2020] pcpu-alloc: [0] 0
[Mon Apr 20 21:10:59 2020] Built 1 zonelists, mobility grouping on. Total pages: 129412
[Mon Apr 20 21:10:59 2020] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=1bc5ffe8-02 ro rootfstype=ext4 rootwait console=null quiet splash vt.global_cursor_default=0 consoleblank=0
[Mon Apr 20 21:10:59 2020] PID hash table entries: 2048 (order: 1, 8192 bytes)
[Mon Apr 20 21:10:59 2020] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[Mon Apr 20 21:10:59 2020] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[Mon Apr 20 21:10:59 2020] Memory: 441340K/522240K available (12288K kernel code, 1053K rwdata, 4204K rodata, 7168K init, 655K bss, 31748K reserved, 49152K cma-reserved, 0K highmem)
[Mon Apr 20 21:10:59 2020] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1200000 - 0xc1900000 (7168 kB)
.data : 0xc1900000 - 0xc1a07658 (1054 kB)
.bss : 0xc1a108e4 - 0xc1ab47a4 ( 656 kB)
[Mon Apr 20 21:10:59 2020] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[Mon Apr 20 21:10:59 2020] ftrace: allocating 40355 entries in 119 pages
[Mon Apr 20 21:10:59 2020] Preemptible hierarchical RCU implementation.
[Mon Apr 20 21:10:59 2020] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[Mon Apr 20 21:10:59 2020] Tasks RCU enabled.
[Mon Apr 20 21:10:59 2020] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[Mon Apr 20 21:10:59 2020] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[Mon Apr 20 21:10:59 2020] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[Mon Apr 20 21:10:59 2020] OMAP clockevent source: timer2 at 24000000 Hz
[Mon Apr 20 21:10:59 2020] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[Mon Apr 20 21:10:59 2020] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[Mon Apr 20 21:10:59 2020] OMAP clocksource: timer1 at 24000000 Hz
[Mon Apr 20 21:10:59 2020] timer_probe: no matching timers found
[Mon Apr 20 21:10:59 2020] Console: colour dummy device 80x30
[Mon Apr 20 21:10:59 2020] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[Mon Apr 20 21:10:59 2020] pid_max: default: 32768 minimum: 301
[Mon Apr 20 21:10:59 2020] Security Framework initialized
[Mon Apr 20 21:10:59 2020] Yama: becoming mindful.
[Mon Apr 20 21:10:59 2020] AppArmor: AppArmor disabled by boot time parameter
[Mon Apr 20 21:10:59 2020] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[Mon Apr 20 21:10:59 2020] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[Mon Apr 20 21:10:59 2020] CPU: Testing write buffer coherency: ok
[Mon Apr 20 21:10:59 2020] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[Mon Apr 20 21:10:59 2020] Setting up static identity map for 0x80100000 - 0x80100060
[Mon Apr 20 21:10:59 2020] Hierarchical SRCU implementation.
[Mon Apr 20 21:10:59 2020] EFI services will not be available.
[Mon Apr 20 21:10:59 2020] smp: Bringing up secondary CPUs ...
[Mon Apr 20 21:10:59 2020] smp: Brought up 1 node, 1 CPU
[Mon Apr 20 21:10:59 2020] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[Mon Apr 20 21:10:59 2020] devtmpfs: initialized
[Mon Apr 20 21:10:59 2020] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[Mon Apr 20 21:10:59 2020] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[Mon Apr 20 21:10:59 2020] futex hash table entries: 256 (order: 2, 16384 bytes)
[Mon Apr 20 21:10:59 2020] pinctrl core: initialized pinctrl subsystem
[Mon Apr 20 21:10:59 2020] DMI not present or invalid.
[Mon Apr 20 21:10:59 2020] NET: Registered protocol family 16
[Mon Apr 20 21:10:59 2020] DMA: preallocated 256 KiB pool for atomic coherent allocations
[Mon Apr 20 21:10:59 2020] omap_hwmod: debugss: _wait_target_disable failed
[Mon Apr 20 21:10:59 2020] cpuidle: using governor menu
[Mon Apr 20 21:10:59 2020] OMAP GPIO hardware version 0.1
[Mon Apr 20 21:10:59 2020] GPIO line 112 (MCASP0_AXR0) hogged as output/low
[Mon Apr 20 21:10:59 2020] No ATAGs?
[Mon Apr 20 21:10:59 2020] hw-breakpoint: debug architecture 0x4 unsupported.
[Mon Apr 20 21:10:59 2020] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[Mon Apr 20 21:10:59 2020] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[Mon Apr 20 21:10:59 2020] edma 49000000.edma: TI EDMA DMA engine driver
[Mon Apr 20 21:10:59 2020] SCSI subsystem initialized
[Mon Apr 20 21:10:59 2020] libata version 3.00 loaded.
[Mon Apr 20 21:10:59 2020] usbcore: registered new interface driver usbfs
[Mon Apr 20 21:10:59 2020] usbcore: registered new interface driver hub
[Mon Apr 20 21:10:59 2020] usbcore: registered new device driver usb
[Mon Apr 20 21:10:59 2020] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[Mon Apr 20 21:10:59 2020] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[Mon Apr 20 21:10:59 2020] media: Linux media interface: v0.10
[Mon Apr 20 21:10:59 2020] Linux video capture interface: v2.00
[Mon Apr 20 21:10:59 2020] pps_core: LinuxPPS API ver. 1 registered
[Mon Apr 20 21:10:59 2020] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[Mon Apr 20 21:10:59 2020] PTP clock support registered
[Mon Apr 20 21:10:59 2020] dmi: Firmware registration failed.
[Mon Apr 20 21:10:59 2020] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[Mon Apr 20 21:10:59 2020] Advanced Linux Sound Architecture Driver Initialized.
[Mon Apr 20 21:10:59 2020] NetLabel: Initializing
[Mon Apr 20 21:10:59 2020] NetLabel: domain hash size = 128
[Mon Apr 20 21:10:59 2020] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[Mon Apr 20 21:10:59 2020] NetLabel: unlabeled traffic allowed by default
[Mon Apr 20 21:10:59 2020] clocksource: Switched to clocksource timer1
[Mon Apr 20 21:10:59 2020] VFS: Disk quotas dquot_6.6.0
[Mon Apr 20 21:10:59 2020] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[Mon Apr 20 21:10:59 2020] NET: Registered protocol family 2
[Mon Apr 20 21:10:59 2020] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[Mon Apr 20 21:10:59 2020] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[Mon Apr 20 21:10:59 2020] TCP: Hash tables configured (established 4096 bind 4096)
[Mon Apr 20 21:10:59 2020] UDP hash table entries: 256 (order: 1, 8192 bytes)
[Mon Apr 20 21:10:59 2020] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[Mon Apr 20 21:10:59 2020] RPC: Registered named UNIX socket transport module.
[Mon Apr 20 21:10:59 2020] RPC: Registered udp transport module.
[Mon Apr 20 21:10:59 2020] RPC: Registered tcp transport module.
[Mon Apr 20 21:10:59 2020] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Mon Apr 20 21:10:59 2020] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[Mon Apr 20 21:10:59 2020] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[Mon Apr 20 21:10:59 2020] audit: initializing netlink subsys (disabled)
[Mon Apr 20 21:10:59 2020] audit: type=2000 audit(0.496:1): state=initialized audit_enabled=0 res=1
[Mon Apr 20 21:10:59 2020] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[Mon Apr 20 21:10:59 2020] zbud: loaded
[Mon Apr 20 21:10:59 2020] NFS: Registering the id_resolver key type
[Mon Apr 20 21:10:59 2020] Key type id_resolver registered
[Mon Apr 20 21:10:59 2020] Key type id_legacy registered
[Mon Apr 20 21:10:59 2020] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[Mon Apr 20 21:10:59 2020] fuse init (API version 7.26)
[Mon Apr 20 21:10:59 2020] aufs 4.14-20180702
[Mon Apr 20 21:10:59 2020] Key type asymmetric registered
[Mon Apr 20 21:10:59 2020] Asymmetric key parser 'x509' registered
[Mon Apr 20 21:10:59 2020] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[Mon Apr 20 21:10:59 2020] io scheduler noop registered
[Mon Apr 20 21:10:59 2020] io scheduler deadline registered
[Mon Apr 20 21:10:59 2020] io scheduler cfq registered (default)
[Mon Apr 20 21:10:59 2020] io scheduler mq-deadline registered
[Mon Apr 20 21:10:59 2020] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[Mon Apr 20 21:10:59 2020] gpio-of-helper ocp:cape-universal: ready
[Mon Apr 20 21:10:59 2020] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[Mon Apr 20 21:10:59 2020] omap_uart 44e09000.serial: no wakeirq for uart0
[Mon Apr 20 21:10:59 2020] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a OMAP UART0
[Mon Apr 20 21:10:59 2020] console [ttyO0] enabled
[Mon Apr 20 21:10:59 2020] omap_uart 481a6000.serial: no wakeirq for uart3
[Mon Apr 20 21:10:59 2020] 481a6000.serial: ttyO3 at MMIO 0x481a6000 (irq = 31, base_baud = 3000000) is a OMAP UART3
[Mon Apr 20 21:10:59 2020] omap_rng 48310000.rng: Random Number Generator ver. 20
[Mon Apr 20 21:10:59 2020] [drm] Initialized vgem 1.0.0 20120112 for virtual device on minor 0
[Mon Apr 20 21:10:59 2020] usbcore: registered new interface driver udl
[Mon Apr 20 21:10:59 2020] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Mon Apr 20 21:10:59 2020] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Mon Apr 20 21:10:59 2020] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Mon Apr 20 21:10:59 2020] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Mon Apr 20 21:10:59 2020] libphy: Fixed MDIO Bus: probed
[Mon Apr 20 21:10:59 2020] tun: Universal TUN/TAP device driver, 1.6
[Mon Apr 20 21:10:59 2020] CAN device driver interface
[Mon Apr 20 21:10:59 2020] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[Mon Apr 20 21:10:59 2020] ehci-platform: EHCI generic platform driver
[Mon Apr 20 21:10:59 2020] ehci-omap: OMAP-EHCI Host Controller driver
[Mon Apr 20 21:10:59 2020] usbcore: registered new interface driver usb-storage
[Mon Apr 20 21:10:59 2020] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[Mon Apr 20 21:10:59 2020] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[Mon Apr 20 21:10:59 2020] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[Mon Apr 20 21:10:59 2020] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[Mon Apr 20 21:10:59 2020] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[Mon Apr 20 21:10:59 2020] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Apr 20 21:10:59 2020] usb usb1: Product: MUSB HDRC host driver
[Mon Apr 20 21:10:59 2020] usb usb1: Manufacturer: Linux 4.14.53+ musb-hcd
[Mon Apr 20 21:10:59 2020] usb usb1: SerialNumber: musb-hdrc.1
[Mon Apr 20 21:10:59 2020] hub 1-0:1.0: USB hub found
[Mon Apr 20 21:10:59 2020] hub 1-0:1.0: 1 port detected
[Mon Apr 20 21:10:59 2020] omap_rtc 44e3e000.rtc: registered as rtc0
[Mon Apr 20 21:10:59 2020] i2c /dev entries driver
[Mon Apr 20 21:10:59 2020] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[Mon Apr 20 21:10:59 2020] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[Mon Apr 20 21:10:59 2020] cpuidle: enable-method property 'ti,am3352' found operations
[Mon Apr 20 21:10:59 2020] sdhci: Secure Digital Host Controller Interface driver
[Mon Apr 20 21:10:59 2020] sdhci: Copyright(c) Pierre Ossman
[Mon Apr 20 21:10:59 2020] omap_hsmmc 48060000.mmc: Got CD GPIO
[Mon Apr 20 21:10:59 2020] mmc1: new high speed MMC card at address 0001
[Mon Apr 20 21:10:59 2020] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
[Mon Apr 20 21:10:59 2020] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[Mon Apr 20 21:10:59 2020] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[Mon Apr 20 21:10:59 2020] mmcblk1rpmb: mmc1:0001 Q2J54A partition 3 512 KiB
[Mon Apr 20 21:10:59 2020] mmcblk1: p1 p2 p3 p4 < p5 p6 >
[Mon Apr 20 21:10:59 2020] sdhci-pltfm: SDHCI platform and OF driver helper
[Mon Apr 20 21:10:59 2020] ledtrig-cpu: registered to indicate activity on CPUs
[Mon Apr 20 21:10:59 2020] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[Mon Apr 20 21:10:59 2020] omap-aes 53500000.aes: will run requests pump with realtime priority
[Mon Apr 20 21:10:59 2020] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[Mon Apr 20 21:10:59 2020] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[Mon Apr 20 21:10:59 2020] random: fast init done
[Mon Apr 20 21:10:59 2020] hidraw: raw HID events driver (C) Jiri Kosina
[Mon Apr 20 21:10:59 2020] usbcore: registered new interface driver usbhid
[Mon Apr 20 21:10:59 2020] usbhid: USB HID core driver
[Mon Apr 20 21:10:59 2020] remoteproc remoteproc0: wkup_m3 is available
[Mon Apr 20 21:10:59 2020] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[Mon Apr 20 21:10:59 2020] wireguard: WireGuard 0.0.20180625 loaded. See www.wireguard.com for information.
[Mon Apr 20 21:10:59 2020] wireguard: Copyright (C) 2015-2018 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[Mon Apr 20 21:10:59 2020] ip_tables: (C) 2000-2006 Netfilter Core Team
[Mon Apr 20 21:10:59 2020] mmc2: new high speed SDIO card at address 0001
[Mon Apr 20 21:10:59 2020] NET: Registered protocol family 10
[Mon Apr 20 21:10:59 2020] Segment Routing with IPv6
[Mon Apr 20 21:10:59 2020] mip6: Mobile IPv6
[Mon Apr 20 21:10:59 2020] NET: Registered protocol family 17
[Mon Apr 20 21:10:59 2020] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[Mon Apr 20 21:10:59 2020] can: controller area network core (rev 20170425 abi 9)
[Mon Apr 20 21:10:59 2020] NET: Registered protocol family 29
[Mon Apr 20 21:10:59 2020] Key type dns_resolver registered
[Mon Apr 20 21:10:59 2020] mpls_gso: MPLS GSO support
[Mon Apr 20 21:10:59 2020] NET: Registered protocol family 44
[Mon Apr 20 21:10:59 2020] omap_voltage_late_init: Voltage driver support not added
[Mon Apr 20 21:10:59 2020] ThumbEE CPU extension supported.
[Mon Apr 20 21:10:59 2020] Registering SWP/SWPB emulation handler
[Mon Apr 20 21:10:59 2020] registered taskstats version 1
[Mon Apr 20 21:10:59 2020] zswap: loaded using pool lzo/zbud
[Mon Apr 20 21:10:59 2020] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[Mon Apr 20 21:10:59 2020] ima: Allocated hash algorithm: sha256
[Mon Apr 20 21:10:59 2020] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[Mon Apr 20 21:10:59 2020] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[Mon Apr 20 21:10:59 2020] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Mon Apr 20 21:10:59 2020] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[Mon Apr 20 21:10:59 2020] remoteproc remoteproc0: powering up wkup_m3
[Mon Apr 20 21:10:59 2020] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[Mon Apr 20 21:10:59 2020] remoteproc remoteproc0: remote processor wkup_m3 is now up
[Mon Apr 20 21:10:59 2020] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[Mon Apr 20 21:10:59 2020] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,GW1A,BBGW19120259'
[Mon Apr 20 21:10:59 2020] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[Mon Apr 20 21:10:59 2020] bone_capemgr bone_capemgr: slot #0: No cape found
[Mon Apr 20 21:10:59 2020] bone_capemgr bone_capemgr: slot #1: No cape found
[Mon Apr 20 21:10:59 2020] bone_capemgr bone_capemgr: slot #2: No cape found
[Mon Apr 20 21:10:59 2020] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[Mon Apr 20 21:10:59 2020] bone_capemgr bone_capemgr: slot #3: No cape found
[Mon Apr 20 21:10:59 2020] bone_capemgr bone_capemgr: initialized OK.
[Mon Apr 20 21:11:00 2020] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[Mon Apr 20 21:11:00 2020] of_cfs_init
[Mon Apr 20 21:11:00 2020] of_cfs_init: OK
[Mon Apr 20 21:11:00 2020] wlan-en-regulator: disabling
[Mon Apr 20 21:11:00 2020] ALSA device list:
[Mon Apr 20 21:11:00 2020] No soundcards found.
[Mon Apr 20 21:11:00 2020] Freeing unused kernel memory: 7168K
[Mon Apr 20 21:11:00 2020] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[Mon Apr 20 21:11:00 2020] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[Mon Apr 20 21:11:00 2020] usb 1-1: Product: USB2.0 Hub
[Mon Apr 20 21:11:00 2020] hub 1-1:1.0: USB hub found
[Mon Apr 20 21:11:00 2020] hub 1-1:1.0: 4 ports detected
[Mon Apr 20 21:11:02 2020] CP437: Invalid argument
[Mon Apr 20 21:11:02 2020] fsck.fat 4.1 (2017-01-24)
0x25: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Automatically removing dirty bit.
Performing changes.
/dev/disk/by-label/resin-boot: 17 files, 292/20431 clusters
[Mon Apr 20 21:11:02 2020] resin-rootA: recovering journal
[Mon Apr 20 21:11:02 2020] resin-rootA: clean, 7724/39936 files, 246827/319488 blocks
[Mon Apr 20 21:11:02 2020] resin-rootB: clean, 11/39936 files, 15349/319488 blocks
[Mon Apr 20 21:11:02 2020] resin-state: recovering journal
[Mon Apr 20 21:11:03 2020] resin-state: clean, 67/5136 files, 1902/20480 blocks
[Mon Apr 20 21:11:03 2020] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[Mon Apr 20 21:11:03 2020] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
[Mon Apr 20 21:11:04 2020] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[Mon Apr 20 21:11:04 2020] aufs au_opts_verify:1622:init[1]: dirperm1 breaks the protection by the permission bits on the lower branch
[Mon Apr 20 21:11:05 2020] systemd[1]: System time before build time, advancing clock.
[Mon Apr 20 21:11:08 2020] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
[Mon Apr 20 21:11:11 2020] random: crng init done
[Mon Apr 20 21:11:17 2020] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[Mon Apr 20 21:11:17 2020] wlcore: WARNING Detected unconfigured mac address in nvs, derive from fuse instead.
[Mon Apr 20 21:11:17 2020] wlcore: WARNING This default nvs file can be removed from the file system
[Mon Apr 20 21:11:17 2020] wlcore: loaded
[Mon Apr 20 21:11:23 2020] Bluetooth: Core ver 2.22
[Mon Apr 20 21:11:23 2020] NET: Registered protocol family 31
[Mon Apr 20 21:11:23 2020] Bluetooth: HCI device and connection manager initialized
[Mon Apr 20 21:11:23 2020] Bluetooth: HCI socket layer initialized
[Mon Apr 20 21:11:23 2020] Bluetooth: L2CAP socket layer initialized
[Mon Apr 20 21:11:23 2020] Bluetooth: SCO socket layer initialized
[Mon Apr 20 21:11:23 2020] Bluetooth: HCI UART driver ver 2.3
[Mon Apr 20 21:11:23 2020] Bluetooth: HCI UART protocol H4 registered
[Mon Apr 20 21:11:23 2020] Bluetooth: HCI UART protocol LL registered
[Mon Apr 20 21:11:23 2020] Bluetooth: HCI UART protocol ATH3K registered
[Mon Apr 20 21:11:23 2020] Bluetooth: HCI UART protocol Three-wire (H5) registered
[Mon Apr 20 21:11:23 2020] Bluetooth: HCI UART protocol QCA registered
[Mon Apr 20 21:11:25 2020] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Mon Apr 20 21:11:25 2020] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[Mon Apr 20 21:11:25 2020] Bluetooth: BNEP filters: protocol multicast
[Mon Apr 20 21:11:25 2020] Bluetooth: BNEP socket layer initialized
[Mon Apr 20 21:11:25 2020] wlcore: PHY firmware version: Rev 8.2.0.0.242
[Mon Apr 20 21:11:25 2020] wlcore: firmware booted (Rev 8.9.0.0.79)
[Mon Apr 20 21:11:25 2020] wlcore: down
[Mon Apr 20 21:11:26 2020] wlcore: PHY firmware version: Rev 8.2.0.0.242
[Mon Apr 20 21:11:26 2020] wlcore: firmware booted (Rev 8.9.0.0.79)
[Mon Apr 20 21:11:26 2020] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Mon Apr 20 21:11:27 2020] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Mon Apr 20 21:11:29 2020] Bridge firewalling registered
[Mon Apr 20 21:11:29 2020] Initializing XFRM netlink socket
[Mon Apr 20 21:11:29 2020] Netfilter messages via NETLINK v0.30.
[Mon Apr 20 21:11:29 2020] ctnetlink v0.93: registering with nfnetlink.
[Mon Apr 20 21:11:30 2020] IPv6: ADDRCONF(NETDEV_UP): balena0: link is not ready
[Mon Apr 20 21:11:31 2020] IPv6: ADDRCONF(NETDEV_UP): br-b0a72ee3d446: link is not ready
[Mon Apr 20 21:11:31 2020] wlcore: down
[Mon Apr 20 21:11:32 2020] wlcore: PHY firmware version: Rev 8.2.0.0.242
[Mon Apr 20 21:11:32 2020] wlcore: firmware booted (Rev 8.9.0.0.79)
[Mon Apr 20 21:11:32 2020] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Mon Apr 20 21:11:33 2020] IPv6: ADDRCONF(NETDEV_UP): supervisor0: link is not ready
[Mon Apr 20 21:11:37 2020] wlan0: authenticate with 7c:d9:5c:95:52:ab
[Mon Apr 20 21:11:37 2020] wlan0: send auth to 7c:d9:5c:95:52:ab (try 1/3)
[Mon Apr 20 21:11:37 2020] wlan0: authenticated
[Mon Apr 20 21:11:37 2020] wlan0: associate with 7c:d9:5c:95:52:ab (try 1/3)
[Mon Apr 20 21:11:37 2020] wlan0: RX AssocResp from 7c:d9:5c:95:52:ab (capab=0x1011 status=0 aid=9)
[Mon Apr 20 21:11:37 2020] wlan0: associated
[Mon Apr 20 21:11:38 2020] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 7c:d9:5c:95:52:ab
[Mon Apr 20 21:11:38 2020] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[Mon Apr 20 21:11:38 2020] wlcore: Association completed.
[Mon Apr 20 21:11:48 2020] udevd[29]: starting version 3.2.9
[Mon Apr 20 21:11:48 2020] udevd[30]: starting eudev-3.2.9
[Mon Apr 20 21:11:50 2020] ip6_tables: (C) 2000-2006 Netfilter Core Team
[Mon Apr 20 21:14:39 2020] udevd[29]: starting version 3.2.9
[Mon Apr 20 21:14:39 2020] udevd[30]: starting eudev-3.2.9
[Tue Apr 21 21:24:52 2020] udevd[29]: starting version 3.2.9
[Tue Apr 21 21:24:52 2020] udevd[30]: starting eudev-3.2.9
[Wed Apr 22 13:22:07 2020] udevd[28]: starting version 3.2.9
[Wed Apr 22 13:22:07 2020] udevd[29]: starting eudev-3.2.9
I’ll prep a bare metal BBG Wirelss board to run the app. Give me ~2 days to see if it crashes.
