Hello there,
I am trying to run the example on the docs section for balena-engine on my Ubuntu Desktop 19.04. I am using version 17.12.0 of balena-engine. I am able to run sudo balena-engine pull resin/rpi-raspbian:jessie fine, but when I run sudo balena-engine run -it --rm resin/rpi-raspbian:jessie /bin/bash I hit the following error: standard_init_linux.go:195: exec user process caused "exec format error". I have googled the error message and it seems to be related to a processor architecture mismatch in the image vs the native running host “armv32/64 vs x86_64” in docker/moby itself. This makes sense to me, however I was wondering if there was a way to run a raspberry-pi image/container on my x86_64 system. Would setting up a virtual machine using the balenaOS be the answer? Are there x86_64 emulated raspberry-pi images but out by balena? Any help would be appreciated.
Thank you,
-Michael Harris
