I am trying to deploy Traefik on my rpi3 project but I keep having the same error. My guess is that error comes when the Image is not on the right platform
2019/10/12 21:32:20 command traefik error: field not found, node: entryPoint
Do I need to specify something on Dockerfile or add a flag on the docker-compose file?
From what i can read from Traefik, it’s already packaged for armv6.
FROM traefik
RUN apk --print-arch
COPY traefik.toml /etc/traefik/traefik.toml
@leross welcome to the forums and thanks for posting! Could you share what you did to resolve the issue? What was wrong with the config file in the end?
It was the config file all this time. The compatibility was broken between traefik v1 and v2. When I tried to start with no config file on my own, it went further.
