I’m using balenaOS 2.32.0+rev1 and device type is Raspberry Pi 3.
I was pointed out by security research company that the version of wpa2_supplicant of the device is a version that is affected by KRACKs (https://www.krackattacks.com/)
The version of wpa_supplicant of my balena OS is v2.6 which is possibility to be attacked.
I’m afraid of this problem.
I found a pull request (https://github.com/balena-os/meta-balena/pull/885) which probably related to this issue, but this doesn’t seem to merge.
Are there any plans to update wpa_supplicant or any other plans?
Best regards.
