Raspberry PI 3 WPA2-Enterprise 802.1x broken on BalenaOS 2.43.0
I’ve run in to an issue with the latest release of Balena, we use WPA2-Enterprise for our WiFi, the connection manager keeps trying to connect to the WiFi but WPA_supplicant is crashing over and over. It does work if i revert to BalenaOS 2.38.
wpa_supplicant Tainted: G WC 4.19.71 #1
Same as the error reported here:
https://www.raspberrypi.org/forums/viewtopic.php?t=247310
Looks like its been fixed upstream https://bugzilla.redhat.com/show_bug.cgi?id=1665608
  • wpa_supplicant-2.8-2.fc30.x86_64
  • kernel-5.1.15-300.fc30.x86_64
How can we get the fix into BalenaOS?
Thanks in advance
I’ve made an issue in meta-balena to bump wpa_supplicant to the latest one.
Are you sure there is a kernel bump that is needed as well? That depends on the pi foundation and they are still on v4.19.
If there is a simple patch that is necessary, we can try to backport it onto v4.19
I tried following the kernel thread but don’t see a specific requirement for the kernel bump.
Regards
ZubairLK
Reading thru here https://www.spinics.net/lists/linux-wireless/msg187184.html looks like it may just be wpa_supplicant
Thank-you for looking closely. Just bumping wpa_supplicant should be easy. Keep an eye on https://github.com/balena-os/meta-balena/issues/1711
@zubairlk I see the issue has been closed nice to see some progress, when can i expect to see an updated image in the dashboard for me to try out? I’m happy to try a beta release if that would help?
I understand that the new wap_supplicant version will ship with balenaOS 2.45.0:
The balenaOS release for Raspberry Pi 3 is currently on 2.44.0+rev2 on the staging environment, and 2.43.0+rev1 on production:
I’ve also created a tracking issue so that this forum thread can be updated when 2.45.0 is released, but unfortunately I don’t an ETA at the moment. I expect it’s a matter of “a few weeks”.
BalenaOS 2.46.1+rev1 for the raspberrypi 3 is now available for download in dashboard. Please let us know how it works for you.
Regards,
Alexandru
Yep tested this yesterday and can confirm this has resolved my issue with 802.1x
