My image is quite large (about 1Go) and it should take a long time to be downloaded on the device.
However the image has not enough time to be downloaded because the supervisor restarts every 10 minutes.
Is it possible to change this parameter?
Hi
Can you grant support access to this device?
Once you have done that, please share the device UUID as well
Hi Anuj,
Thank you for your response!
I changed the sd-card (switched to SanDisk Extreme Plus 32Go) and it works!
I think the problem is already described and discussed here:
I will wait until a solution is provided for slow sd cards
