Static ip for balena os docker
Hi, is possible to give balena os in docker variant a static ip?
I tried to give the start up Script a static IP with a custom Network but then the vpn public access was not working.
Hi, you should be able to do it like this: https://www.balena.io/docs/reference/OS/network/2.x/#setting-a-static-ip
Can you give that a try on your side?
Tried that also did not had any effect
