Issue trying to SSH into container from running on RPi2 from Windows 10 machine, possibly related to:
When attempting from same environment (Win10, Git Bash, MinGW64), I get:
$ balena local ssh balena-rpi2-dev.local --container main_1_1 sh: -c: line 0: syntax error near unexpected token `then' sh: -c: line 0: `$(if [ -f /usr/bin/balena ]; then echo \"balena\"; else echo \"docker\"; fi) exec -ti main_1_1 /bin/sh -c $\'if [ -e /bin/bash ]; then exec /bin/bash; else exec /bin/sh; fi'"' Connection to balena-rpi2-dev.local closed.
But when I try to connect via PowerShell, I get:
PS C:\WINDOWS\system32> balena local ssh 192.168.0.17 --container main_1_1 sh: $(if [ -f /usr/bin/balena ]; then echo "balena"; else echo "docker"; fi): No such file or directory Connection to 192.168.0.17 closed.
I can ssh into the host with no problem at all, but not the container.
root@balena-rpi2-dev:~# balena-engine version
Client:
Version: 17.12.0-dev
API version: 1.35
Go version: go1.9.7
Git commit: dceb2fc48071b78a8a828e0468a15a479515385f
Built: Thu Jan 17 15:08:33 2019
OS/Arch: linux/arm
Experimental: false
Orchestrator: swarmServer:
Engine:
API version: 1.35 (minimum version 1.12)
Go version: go1.9.7
OS/Arch: linux/arm
Experimental: true
balena-cli version is 10.8.0
Any thoughts?
