I tried to connect with local ssh from my pc to the host Os. i use balena cli on windows.
I run the command balena local ssh and after that it says to Select a container (? Select a container).
I choose the container /resin_supervisor , and i get the message : sh: $(if [ -f /usr/bin/balena ]; then echo “balena”; else echo “docker”; fi): No such file or directory Connection to 192.168.1.100 closed.
The Supervisor container is not one that is meant to be SSHd into via balena-cli. This is the balena Supervisor, which manages the download, initialisation, configuration and running of user applications on a device. It is a very slim container and therefore doesn’t include the services required to balena ssh into. All user application services, however, should be.
