Hey @cnr, unfortunately this is not yet possible. I’ve created a tracking issue for this, but most likely this would be added as a flag to balena push (providing arguments to the git server can be very roundabout).
Do you have any recommendations about how to build on multiple arches? We want to have a fast local development process on x86 (cannot use the development mode on our device because our developer is remote, but the device is with us), coupled with a git push balena deployment process to test the code is working as expected on the destination device.
mount binfmt_misc -t binfmt_misc /proc/sys/fs/binfmt_misc
echo ':arm:M::\x7fELF\x01\x01\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x02\x00\x28\x00:\xff\xff\xff\xff\xff\xff\xff\x00\xff\xff\xff\xff\xff\xff\xff\xff\xfe\xff\xff\xff:/usr/bin/qemu-arm-static:' > /proc/sys/fs/binfmt_misc/register
should allow you to run our base images for ARM on your x86 machine (as long as you have root access on the computer where you want to do this to run that hack).
Sorry, it has taken me a while to get back to this.
Yes, development mode has bind mounts.
Development mode also has a wrapper script that executes the container with the proper options and arguments.
We haven’t really solved the problem, we’ve just decided that we will only use one docker-compose file and that will service balenaCloud, and everything else we will call manually in development mode (with docker run or similar).
Not sure if that is helpful, but I figured I’d try to get back to you and see if I can shed some light.
