Does resin.io always assume that every container needs to continuously keep running?
I’ve built a simple Dynamic DNS application which consists of two containers. One configures the Dynamic DNS service settings (based on environment variables) and then exists immediately(edit: added for clarity). Another one checks the device’s IP address every 5 minutes and performs an update if necessary.
Currently, I need to insert a dummy wait statement, so that resin.io does not try to continuously restart the first one (I assume this operation is not very power efficient, especially given that it’s unnecessary):
Is there a way to make resin.io be okay with a short-lived container? Or is there a better solution to my problem? Ideally I’d like to keep the container separation between the configuration and IP update.
(On a related note, I suppose it would be more efficient to fire up the IP update container every 5 minutes. Now it takes up RAM on just waiting for another check. This may or may not matter, depending on whether you can run other containers only when this one is down.)
In any case, resin.io is absolutely amazing – creating this project was a pleasure! Thanks for making it happen!
Thanks for your reply! Can you elaborate how this will help? I thought that INITSYSTEM was only controlling processes inside the container, while my problem is with the hypervisor.
The hypervisor is unhappy that my configure container exits immediately, so it restarts it. And then my container exists immediately again, and this keeps going forever.
Hi. I think I have misunderstood what you wanted. I pointed you to using systemd in the container so that the container finishes the work and remains running, without being restarted. You could leave your container always running and just do it’s intended job every 5 minutes.
But it seems you want the container to exit and not restart until after 5 minutes or so. In such a case, you could employ the use of the device config variable RESIN_APP_RESTART_POLICY which should support docker’s restart policies as outlined here: https://docs.docker.com/engine/reference/run/#restart-policies---restart
I don’t find this documented anymore in our docs, let me ask around and get back to you.
Also, not sure how you would go around to have these restart policies only for one of your containers.
PS: ddclient is still running continuously, and just waits 5 minutes between IP address checks. I think that this is fine - I didn’t see an option in the compose file reference to schedule the container to start from scratch every 5 minutes. It’s probably even more power efficient to have it wait 5 minutes between doing work, rather than restart all the time.
