SOLVED - Help - Exposing container port outside
Greetings,
I’m a developer and I’m completely new with resin.io.
I’m having an issue exposing the port of a container to the outside.
I deploy my container in the device, which has an exposed port 8443.
I log on the device and I add the port redirection from the device to the container. (as instructed in the FAQs: https://docs.resin.io/troubleshooting/faq/#how-can-i-forward-my-container-ports-)
iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 8443 -j REDIRECT --to-port 8443
But when I try to access the public webpage, I get no page.
PS: when using docker directly in my PC (using Docker toolbox)
1 - replacing base image: resin/raspberrypi3-alpine-openjdk:openjdk-8-jre for openjdk:8-jre
2 - I can run and access the published webpage using the following command:
docker run -it -d -p 8443:8443 --name sample-site joaocarloscg/container-sample:latest
Am I missing any important step?
Edit: the ports are automatically exposed, the issue was elsewhere. to close/delete
Exposing container port outside is not an easy task to handle it, Same goes with using the projector outside of your home as that may require a lot of hustle to get this done. Here in upper line mentioned post I added reference to a post purposing the solution of possible problem while using projector screen outside of your home.
