SMA antenna connector for balenaFin housing
Hi there,
Do you have any suggestions which kind of SMA antenna connector you are using for your balenaFin in the housing?
Best regards
Flo356
Hi!
We have a blog post where we use balenaFin as an outdoors lora gateway! I think this post will give you some ideas about which antenna connectors you can use with balenaFin :slight_smile:
Thanks for your link. I will try to get our findings in the modular DIN housing for the balena Fin regarding ideal cable length from modem to the antenna breakout in the housing.
