Hey @Tissy if you specify variables in this way they will work and be present for the build and the resultant image, but they’re isolated from the cloud backend, and so won’t propagate back ‘upwards’ and display in the cloud UI.
So to answer your question, you can specify them at build (and it will work), but this method is not integrated with the cloud UI.
