Hi, I’m currently trying to use balena to run a fleet of Rpi’s with a sensor attached to the device over USB. To do this I need to change the device cgroup rules to ‘c 189:* rmw’ which would be supported with a regular docker run command or with a docker-compose version 2.4. since balena is currently relying on a compose version of 2.1 it’s pretty difficult to do this. is there any chance anyone knows of a work around?
@Carottid Welcome the the forums!
I’m not familiar with setting cgroup rules but I do know that compose file support is based on version 2.4. This reference doesn’t specifically mention device_cgroup_rules being supported though.
I just did a test balena push with this compose file and didn’t get any errors. Not sure if it did anything with the cgroup rules or how to test that… but it is worth a test in your project.
version: '2.4'
services:
idler:
image: balenalib/intel-nuc-alpine
privileged: true
labels:
io.balena.features.dbus: '1'
io.balena.features.sysfs: '1'
device_cgroup_rules:
- "c 189:* rmw"
command: balena-idle
good luck!
//Sam
Hi Sam, thanks for the quick response. With your compose file I just got:
`Unsupported composition version
ValidationError: Unsupported composition version
at Object.normalize (/usr/local/lib/balena-cli/node_modules/resin-compose-parse/build/compose.js:68:23)
at createProject (/usr/local/lib/balena-cli/build/utils/compose.js:23:33)
at loadProject (/usr/local/lib/balena-cli/build/utils/compose_ts.js:73:12)
at async Object.deployToDevice (/usr/local/lib/balena-cli/build/utils/device/deploy.js:98:21)
at async PushCmd.pushToDevice (/usr/local/lib/balena-cli/build/commands/push.js:93:13)
at async PushCmd.run (/usr/local/lib/balena-cli/build/commands/push.js:36:17)
at async PushCmd._run (/usr/local/lib/balena-cli/node_modules/@oclif/command/lib/command.js:43:20)
at async Config.runCommand (/usr/local/lib/balena-cli/node_modules/@oclif/config/lib/config.js:175:24)
at async CustomMain.run (/usr/local/lib/balena-cli/node_modules/@oclif/command/lib/main.js:27:9)
at async CustomMain._run (/usr/local/lib/balena-cli/node_modules/@oclif/command/lib/command.js:43:20)
at async /usr/local/lib/balena-cli/build/app.js:76:13
at async Promise.all (index 2)
at async oclifRun (/usr/local/lib/balena-cli/build/app.js:94:5)
at async Object.run (/usr/local/lib/balena-cli/build/app.js:107:9)
at async run (/usr/local/lib/balena-cli/bin/run:20:2)
https://www.balena.io/docs/reference/balena-cli/#support-faq-and-troubleshooting`
my balena-cli was an old version installed through homebrew… the new updated version allows me to deploy with 2.4
