I use this GitHub - balenalabs-incubator/wifi-repeater: Easily create a WiFi Access Point or WiFi repeater with balenaOS
Works great on the Raspberry pi 4 b 8gb. Easy to run and install with balena. I use it as acces point. But i want wpa2. Wpa is not safe. So how to get wpa2. Is it possible to write a command or configure it? Thanks
Hello, WPA2 support is currently not available in this project but rather an enhancement that is already on our list: Use WPA2 instead of WPA · Issue #2 · balenalabs-incubator/wifi-repeater · GitHub - we’ll let you know when it gets added, but there is currently no ETA.
Thanks for answer
