Running systemctl within dockerfile
I am trying to run an application that consists of two separate Python-Sub-Applications on an resin.io enabled Raspberry Pi.
On a non resin.io enabled Raspberry Pi I am using systemctl for this and create two different services which are started during boot up of the device.
So I am looking for a way to use systemctl within a resin.io Dockerfile. Is this possible? Any sample of how such a dockerfile would look like is greatly appreciated!
Simon
Hi @simonkemper,
I’d guess you can copy the service files in your Dockerfile to the and then use systemctl enable on them? The relevant sections cut out of a Dockerfile would be these:
ENV INITSYSTEM on
COPY myservice.service /lib/systemd/system/
RUN systemctl enable myservice.service
See the code in this example project: https://github.com/resin-io-playground/resin-bbgw-bluetooth
Is this what you are looking for?
This is exactly what I was looking for. I’ll give it a try and get back with details!
