Error starting systemd service
I want to run my application as a service which starts on boot and always restarts if it exists for any reason.
To do this I’m trying to create and run a systemd service. However, I get an error when I manually trying to run systemctl start /etc/systemd/system/my_service.service saying Failed to start etc-systemd-system-ccon\x2dism\x2dcloud.service.mount: Unit etc-systemd-system-ccon\x2dism\x2dcloud.service.mount failed to load: No such file or directory.
The content of the my_service.service file is:
[Unit]
Description=Main Application Service
[Service]
EnvironmentFile=/etc/docker.env
Type=simple
ExecStart=/app/my-binary
Restart=always
[Install]
WantedBy=multi-user.target
My dockerfile:
FROM resin/armv7hf-debian
# Copy repository content recursively to the 'app' folder
COPY . /app
# Switch on systemd init system in container and add the ccon-ism-cloud service
ENV INITSYSTEM on
COPY my_service.service /etc/systemd/system/my_service.service
RUN systemctl enable /etc/systemd/system/my_service.service
CMD /bin/bash
:speech_balloon:I’ve not had any experience as a service, and can ask around, but I do have experience of my applications aborting and (from memory, don’t happen to have a project in this state at the moment) the docker container restarts once execution ends.
Did this solution work for you? If not I will ask around, but am hopeful that the simpler solution might work for you.
I’ve used these lines differently:
COPY my_service.service /lib/systemd/system/
RUN systemctl enable my_service
I’ve created a small service like that for testing (running a short ping on boot), and works like a charm, runs on start just fine.
Also, since it’s unclear why the etc-systemd-system-ccon\x2dism\x2dcloud.service.mount is mentioned by systemd, I did a quick scan, don’t see that in the resin.io side.
What resinOS version are you using? Is it possible to share a link to your whole project to get some more idea what might be going wrong?
Thanks @imrehg, that worked for me!
