Hi, I try for hours to get the cec-client working in a Node Docker Container.
FROM balenalib/%%RESIN_MACHINE_NAME%%-node:build as build
COPY package.json package.json
RUN npm install --only=production
# The run time container that will go to devices
FROM balenalib/%%RESIN_MACHINE_NAME%%-node:run
# install dependencies
RUN apt-get update && apt-get install -y --no-install-recommends cec-utils
# Grab our node modules for the build step
COPY --from=build ./node_modules ./node_modules
COPY eis-api.js eis-api.js
CMD ["node", "eis-api.js"]
But I when I try to connect to the CEC Device I get the following error:
root@f2c57ff5760c:/# cec-client
No device type given. Using 'recording device'
CEC Parser created - libCEC version 4.0.4
no serial port given. trying autodetect: FAILED
The running container is running in priviliged mode and also has the device /dev/vchiq and /dev/ttyACM0 mounted. Do you have an idea how to get the cec-client working in a BalenaOS Docker Container?
I am not familiar with the project you are trying to build, though I searched for the error and I found this https://raspberrypi.stackexchange.com/questions/72032/testing-cec-on-raspbian can you try running tvservice -m CEC ? And see if the monitor is supporting CEC. Also can you explain to me a bit about the project?
it seems that there is no package for tvservice on the balenaOS Raspberry Image. Is it possible that I need the cec-utils Package explicity for raspberry or from raspbian deb source?
I don’t know if the problem is the docker container running on raspberry. In some documents I find that cec-client is using device “RPI” to communicate with the cec Controller. But that is not an normal device like /dev/vchiq or anything else. So it seems that there is another connection and perhaps I do need a special cec-client Version for raspberry.
Can you try to use the raspbian base image instead?
You should change it to FROM balenalib/rpi-raspbian
You might have to install nodejs in the base image.
You can install packages using our install_packages utility. tvservice is already included in the base image and you can install cec utility using RUN install_packages cec-utils
We have colleagues who have been successful in using both cec-utils and tvservice.
Hope this helps
I now tried to use the raspberry image but the qemu seems not to support arm1176 on my machine.
[Build] eis-api Step 3/8 : RUN ["/tmp/qemu-execve","-execve","/bin/sh","-c","install_packages nodejs cec-utils"]
[Build] eis-api ---> Running in 22cf5f561530
[Build] eis-api unable to find CPU model 'arm1176'
To make sure that we talk about the same: I try to build the Application on an Ubuntu VM with emulated Command: “balena deploy eis-rpi4-beta --source ./ --emulated --build --logs”
That fails now. The target machine is a RPi 4.
Hi there, I’ve tested this on macOS and the step RUN install_packages nodejs cec-utils appears to build fine for both balena build --deviceType raspberrypi4-64 --arch aarch64 and --deviceType raspberrypi4-64 --arch armv7l.
Are you able to try the build natively without using a VM and/or git push directly to our builders, which have native ARM support?
I tried a few things now an i’m really desperated. Beacause it didn’t worked on my Azure VM I now try to build the Image directly on my RPi 4 in Local Mode. My Dockerfile looks like that:
WORKDIR /app
RUN install_packages tar cec-utils
RUN uname -a
RUN curl -skL https://deb.nodesource.com/setup_12.x | sudo -E bash -
RUN apt-get install -y nodejs
RUN node -v
RUN npm -v
COPY start.sh start.sh
CMD ["/bin/sh", "start.sh"]
But now I can’t install node beacuse the compiled releases doesn’t exist for the aarc64 architecture.
This is the output of the uname -a command:
Linux 0355e9428ea6 4.19.75 #1 SMP PREEMPT Mon Mar 23 11:50:49 UTC 2020 aarch64 GNU/Linux
Can you explain to me which architecture is used von RPI 3B+ and RPi 4 (my Target systems). My RPi 4 (Raspberry Pi 4 Model B Rev 1.1) with original Raspbian has an armv71 Architecture, the one with balena OS Image has aarch64. It’s confusing me. I think thats the reason why pre-build Packages like cec-client or now NodeJS for RPi doesnt work on balenaOS?!?
My Application (a simple Kiosk Browser) work until I setup another service which should provide a node Server to switch the TV on and off by using the cec-client. This failes now.
To answer your question - we have a 64 bit variant of the balenaOS. You can find more about it here. Are you trying to use that?
If you take a look at our devices page, you will find what BALENA_ARCH is used for each device type. See here. You can find that RPi3 has armv7hf as well as aarch64.
Ok I got some more information. When I try to build the container without node on my RPi 4 in Local mode. The build succeeds and i can use cec-client. But when I build this on my Azure VM with emulated flag and --arch aarch64 the build failes with following message:
[Build] eis-api Step 4/8 : RUN ["/tmp/qemu-execve","-execve","/bin/sh","-c","install_packages tar cec-utils"]
[Build] eis-api ---> Running in 5378ad26427c
Where does the CPU model ‘arm1176’ comes from? Why does the architecture changes for this command or image?BalenaDeployErrorLog.log (6.7 KB)
So it seems that the rpi-raspbian Image is only for RPi3? But with this Image cec-client works but a) I’m not able to install node and b) I can build this Image only on my Raspberry. Not with qemu emulation.
When I use an aarch64 Image the cec-client doesn’t work and can’t communicate with the attached TV.
Does anybody has an idea how to setup a Container which use the aarch64 Architecture and has a running cec-client for raspberry in it?
Hi @holg, I see what’s you mean, if the balenalib/rpi-raspbian works for you regarding the ceclib and you want a specific node version that it is not pre-built for you, you can compile it from the source code here https://nodejs.org/en/download/ .
