I want to run a script when I plug in an USB stick. The script mounts the USB drive, reads a file from the drive, does some config work and unmounts the device.
I tried to do it with udev by creating the following rule in /etc/udev/rules.d/udev-plug-usb.rules
ACTION=="add", SUBSYSTEM=="usb", RUN+="touch /usr/src/app/success"
(for testing purpose, I only want to create a file success
. The script itself would mount the stick and do it’s work.)
However, this doesn’t work. I tried to reload the rules
udevadm control --reload-rules && udevadm trigger
but this didn’t have any effect. Then I integrated the file in my Dockerfile, and reboot the device, nothing changed.
When I log at the monitor with udevadm monitor --env
and I plug in my usb stick, I get a lot of logs like this:
KERNEL[7842.430544] add /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3 (usb)
ACTION=add
BUSNUM=001
DEVNAME=/dev/bus/usb/001/015
DEVNUM=015
DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3
DEVTYPE=usb_device
MAJOR=189
MINOR=14
PRODUCT=13fe/4200/100
SEQNUM=7609
SUBSYSTEM=usb
TYPE=0/0/0
So my questions are:
- Why does the
touch
not fire when I plug in my USB Stick? - Is there an easier way to run a script when an USB stick is plugged in (any stick, not a specific one)?
