I made a mount.sh file inspired by balena-storage (thanks for that!). It works when I login to the container via the dashboard and run the script manually. It hangs with unpopulated vars when the container runs it when starting (a script that runs the script). I think it’s a permissions issue or script running script thing.
mount.sh:
# Automatically mount a USB drive by specified volume name.
# Note: make sure to have USB_VOLUME_NAME set in env vars.
# Thanks: https://github.com/balena-io-playground/balena-storage
echo "Checking for USB_VOLUME_NAME..."
echo "A"
if [[ -z $USB_VOLUME_NAME ]]; then
echo "Make sure to set environment variable USB_VOLUME_NAME in order to find a connected USB drive by that label and connect to it. Exiting..." >> /usr/src/app/mount.log
exit 1
fi
echo "B"
# Get device by label env var set in balena.io dashboard device env vars
USB_DEVICE=$(blkid -L $USB_VOLUME_NAME)
if [[ -z $USB_DEVICE ]]; then
echo "Invalid USB_DEVICE name: $USB_DEVICE" >> /usr/src/app/mount.log
exit 1
fi
echo $USB_DEVICE
echo "C"
# Get extra device info
ID_FS_TYPE=${ID_FS_TYPE:=$(/bin/udevadm info -n $USB_DEVICE | /usr/bin/awk -F "=" '/ID_FS_TYPE/{ print $2 }')}
ID_FS_UUID_ENC=${ID_FS_UUID_ENC:=$(/bin/udevadm info -n $USB_DEVICE | /usr/bin/awk -F "=" '/ID_FS_UUID_ENC/{ print $2 }')}
ID_FS_LABEL_ENC=${ID_FS_LABEL_ENC:=$(/bin/udevadm info -n $USB_DEVICE | /usr/bin/awk -F "=" '/ID_FS_LABEL_ENC/{ print $2 }')}
MOUNT_POINT=/mnt/$USB_VOLUME_NAME
echo $ID_FS_TYPE
echo $ID_FS_UUID_ENC
echo $ID_FS_LABEL_ENC
echo $MOUNT_POINT
echo "D"
# Bail if file system is not supported by the kernel
if ! /bin/grep -qw $ID_FS_TYPE /proc/filesystems; then
echo "File system not supported: $ID_FS_TYPE" >> /usr/src/app/mount.log
exit 1
fi
echo "E"
# Mount device
if /bin/findmnt -rno SOURCE,TARGET $USB_DEVICE >/dev/null; then
echo "Device $USB_DEVICE is already mounted!" >> /usr/src/mount.log
else
echo "Mounting - Source: $USB_DEVICE - Destination: $MOUNT_POINT" >> /usr/src/app/mount.log
/bin/mkdir -p $MOUNT_POINT
/bin/mount -t $ID_FS_TYPE -o rw $USB_DEVICE $MOUNT_POINT
fi
echo "F"
When the container runs the script, it gets stuck after “D”, with ID_FS_TYPE, ID_FS_UUID_ENC and ID_FS_LABEL_ENC being empty (a good reason to hang).
output:
22.07.20 10:36:27 (-0600) server Checking for USB_VOLUME_NAME...
22.07.20 10:36:27 (-0600) server A
22.07.20 10:36:27 (-0600) server B
22.07.20 10:36:27 (-0600) server /dev/sda1
22.07.20 10:36:27 (-0600) server /mnt/MYDRIVE
22.07.20 10:36:27 (-0600) server D
My dockerfile.template:
FROM balenalib/%%BALENA_MACHINE_NAME%%-node
# Enable udev for detection of dynamically plugged devices
ENV UDEV=on
COPY udev/usb.rules /etc/udev/rules.d/usb.rules
# Install dependencies
RUN install_packages util-linux
WORKDIR /usr/src/app
# Move scripts used for mounting USB
COPY scripts scripts
RUN chmod +x scripts/*
# server.js will run when container starts up on the device
CMD ["/bin/bash", "/usr/src/app/scripts/start.sh"]
start.sh:
echo "Mounting USB drive..."
cd /usr/src/app/scripts
/bin/bash mount.sh
echo "Starting server..."
cd /usr/src/app
/usr/local/bin/yarn run serve
Any ideas on what’s up? I’m so close and could use a professional opinion.
