Run OpenBalena on BalenaOS
Is it possible to run OpenBalena on BalenaOS?
I’m looking to run OpenBalena on an NUC device that can act as the “master” for a network of Raspberry Pis running BalenaOS on a private network. This would also act as the NAT gateway for the Pi’s.
Is this something that’s been thought of or done before?
  • Darryl
Hello, yes it’s possible.
You can use the https://www.balena.io/open/docs/getting-started/ steps in a Dockerfile
