I’m using that project: GitHub - balenablocks/browser: A drop-in web browser block
The first push work successfully. After that, it’s always fail.
Tried With RPI3 and RPI3 64bits and recreated the app. No success.
In local build I got no issue but the container has an error :
standard_init_linux.go:211: exec user process caused "exec format error"
Remote build log:
ubuntu@DESKTOP-STEEVE:/mnt/c/Users/steev/source/repos/github.com/browser$ balena push Dashboard --debug
Warning: Node version "v15.13.0" does not match required versions ">=10.20.0 <13.0.0".
This may cause unexpected behavior. To upgrade Node, visit:
https://nodejs.org/en/download/
[debug] new argv=[/usr/bin/node,/usr/local/bin/balena,push,Dashboard] length=4
[Debug] Using build source directory: .
[Debug] Pushing to cloud for application: Dashboard
/ Packaging the project source...[Debug] docker-compose.yml file found at "/mnt/c/Users/steev/source/repos/github.com/browser"
[debug] Connecting to builder at https://builder.balena-cloud.com/v3/build?slug=steeve_s_organization%2Fdashboard&dockerfilePath=&emulated=false&nocache=false&headless=false
\ Uploading source package to balenaCloud[debug] received HTTP 200 OK
[debug] handling message: {"type":"metadata","resource":"buildLogId","value":1871099}
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Starting build for dashboard, user g_steeve_g_lambert"}
[Info] Starting build for dashboard, user g_steeve_g_lambert
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Dashboard link: https://dashboard.balena-cloud.com/apps/1849440/devices"}
[Info] Dashboard link: https://dashboard.balena-cloud.com/apps/1849440/devices
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Building on arm06"}
[Info] Building on arm06
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Pulling previous images for caching purposes..."}
[Info] Pulling previous images for caching purposes...
[debug] handling message: {"type":"metadata","resource":"cursor","value":"erase"}
[debug] handling message: {"message":"\u001b[32m[Success]\u001b[39m Successfully pulled cache images"}
[debug] handling message: {"message":"\u001b[35m[browser]\u001b[39m [> ] 0%"}
[browser] [> ] 0%
[browser] [> ] 0%
[debug] handling message: {"message":"\u001b[35m[browser]\u001b[39m [=> ] 1%"}
[browser] [=> ] 1%
--REDACTED--
[debug] handling message: {"message":"\u001b[35m[browser]\u001b[39m [=========================================================>] 99%"}
[browser] [=========================================================>] 99%
[debug] handling message: {"message":"\u001b[35m[browser]\u001b[39m [=========================================================] 100%"}
[browser] [=========================================================] 100%
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Generating image deltas from release fe542cd5babf7b8869d6727dae539ae2 (id: 1871080)"}
[Info] Generating image deltas from release fe542cd5babf7b8869d6727dae539ae2 (id: 1871080)
[debug] handling message: {"message":"\u001b[33m[Warning]\u001b[39m Failed to generate deltas due to an internal error; will be generated on-demand"}
[Warning] Failed to generate deltas due to an internal error; will be generated on-demand
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Uploading images"}
[Info] Uploading images
[debug] handling message: {"message":"[==================================================>] 100%","replace":true}
[==================================================>] 100%[debug] handling message: {"message":"[==================================================>] 100%","replace":true}
[==================================================>] 100%[debug] handling message: {"type":"metadata","resource":"cursor","value":"erase"}
[debug] handling message: {"message":"\u001b[32m[Success]\u001b[39m Successfully uploaded images"}
[debug] handling message: {"message":"\u001b[31m[Error]\u001b[39m Error:: It is necessary that each release that has a release version1 and has a status that is equal to \"success\" and is not invalidated, belongs to an application that owns exactly one release that has a release version2 that is equal to the release version1 and has a status that is equal to \"success\" and is not invalidated.","isError":true}
[Error] Error:: It is necessary that each release that has a release version1 and has a status that is equal to "success" and is not invalidated, belongs to an application that owns exactly one release that has a release version2 that is equal to the release version1 and has
a status that is equal to "success" and is not invalidated.
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Built on arm06"}
[Info] Built on arm06
[debug] handling message: {"message":"\u001b[32m[Success]\u001b[39m Release successfully created!"}
[Success] Release successfully created!
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Release: \u001b[34m7c33c94475aa115ee82fc2c59863f866\u001b[39m (id: \u001b[32m1871099\u001b[39m)"}
[Info] Release: 7c33c94475aa115ee82fc2c59863f866 (id: 1871099)
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m \u001b[90m┌─────────\u001b[39m\u001b[90m┬────────────\u001b[39m\u001b[90m┬─────────────────────┐\u001b[39m"}
[Info] ┌─────────┬────────────┬─────────────────────┐
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m \u001b[90m│\u001b[39m \u001b[1mService\u001b[22m \u001b[90m│\u001b[39m \u001b[1mImage Size\u001b[22m \u001b[90m│\u001b[39m \u001b[1mBuild Time\u001b[22m \u001b[90m│\u001b[39m"}
[Info] │ Service │ Image Size │ Build Time │
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m \u001b[90m├─────────\u001b[39m\u001b[90m┼────────────\u001b[39m\u001b[90m┼─────────────────────┤\u001b[39m"}
[Info] ├─────────┼────────────┼─────────────────────┤
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m \u001b[90m│\u001b[39m browser \u001b[90m│\u001b[39m 887.52 MB \u001b[90m│\u001b[39m 1 minute, 3 seconds \u001b[90m│\u001b[39m"}
[Info] │ browser │ 887.52 MB │ 1 minute, 3 seconds │
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m \u001b[90m└─────────\u001b[39m\u001b[90m┴────────────\u001b[39m\u001b[90m┴─────────────────────┘\u001b[39m"}
[Info] └─────────┴────────────┴─────────────────────┘
[debug] handling message: {"message":"\u001b[36m[Info]\u001b[39m Build finished in 1 minute, 43 seconds"}
[Info] Build finished in 1 minute, 43 seconds
[debug] handling message: {"message":"\u001b[1m\u001b[34m\t\t\t \\\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t \\\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t \\\\\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t \\\\\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t >\\/7\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t _.-(6' \\\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t (=___._/` \\\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t ) \\ |\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t / / |\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t / > /\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t j < _\\\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t _.-' : ``.\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t \\ r=._\\ `.\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t<`\\\\_ \\ .`-.\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t \\ r-7 `-. ._ ' . `\\\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t \\`, `-.`7 7) )\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t \\/ \\| \\' / `-._\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t || .'\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t \\\\ (\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t >\\ >\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t ,.-' >.'\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t <.'_.''\u001b[39m\u001b[22m\n\u001b[1m\u001b[34m\t\t\t <'\u001b[39m\u001b[22m","isSuccess":true}
>\/7
_.-(6' \
(=___._/` \
j < _\
_.-' : ``.
\ r=._\ `.
<`\\_ \ .`-.
\ r-7 `-. ._ ' . `\
\`, `-.`7 7) )
\/ \| \' / `-._
<.'_.''
Remote build failed
RemoteBuildFailedError: Remote build failed
at handleRemoteBuildStream (/usr/local/lib/node_modules/balena-cli/build/utils/remote-build.js:82:15)
at processTicksAndRejections (node:internal/process/task_queues:94:5)
at async Object.startRemoteBuild (/usr/local/lib/node_modules/balena-cli/build/utils/remote-build.js:63:13)
at async PushCmd.pushToCloud (/usr/local/lib/node_modules/balena-cli/build/commands/push.js:79:27)
at async PushCmd.run (/usr/local/lib/node_modules/balena-cli/build/commands/push.js:33:17)
at async PushCmd._run (/usr/local/lib/node_modules/balena-cli/node_modules/@oclif/command/lib/command.js:43:20)
at async Config.runCommand (/usr/local/lib/node_modules/balena-cli/node_modules/@oclif/config/lib/config.js:175:24)
at async CustomMain.run (/usr/local/lib/node_modules/balena-cli/node_modules/@oclif/command/lib/main.js:27:9)
at async CustomMain._run (/usr/local/lib/node_modules/balena-cli/node_modules/@oclif/command/lib/command.js:43:20)
at async /usr/local/lib/node_modules/balena-cli/build/app.js:65:13
at async Promise.all (index 1)
at async oclifRun (/usr/local/lib/node_modules/balena-cli/build/app.js:83:5)
at async Object.run (/usr/local/lib/node_modules/balena-cli/build/app.js:96:9)
at async run (/usr/local/lib/node_modules/balena-cli/bin/balena:20:2)
